STL to solid model help
Can somebody please convert this to a solid model? I don't have solidworks or a utility to do this.
Re: STL to solid model help
What format do you want?
A *.prt and or *.stp.
Thanks a bunch |
Here you go:
I am getting a translation error bringing it into Inventor. Can you make *.IPT? or step please.
Thanks aganin. |
Try this:
#7
I don't understand what the problem is, but don't see any geometry from your conversion.
Can somone else give it a try? I need to be able to open this in inventor as a solid and cut parts away. Thanks again. Last edited by Chadfrom308 : 16-02-2014 at 13:36. |
#8
I thought Inventor could open STL files by simply importing them. Am I wrong there?
#9
It does. I can open the STL, but it is a surface, not a solid body. I need the file converted to a solid body so that I can edit it like a regular part.
There is an option in Solidworks. When you open the file, from the options menue, you can open as a solid body. |
#10
Depending on which version of Inventor you are using, there is a Mesh Enabler application that does what you want.
Here is a tutorial explaining the process. http://grabcad.com/questions/tutoria...odesk-inventor |
#11
I've seen this, but Mesh Enabler isn't a free download.
