Go to Post If regolith ever makes a return, I will jump out of a window. - Oblarg [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 16-02-2014, 16:10
duane's Avatar
duane duane is offline
FRC #0701 (RoboVikes)
duane is an unknown quantity at this point
Send a message via AIM to duane
Jaguar Limit Switch Not Working
We have a jaguar with the limit switch jumpers removed. The Jaguar is still able to go forward and reverse.
We find this quite baffling. I can't find a mode for the Jaguar where this happens.
We're looking for ideas for how this might be possible.
Thanks
Duane Murphy
Mentor - Software
Vanden Vikings FIRST Team 701
http://www.vandenrobotics.com
Unread 16-02-2014, 19:57
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: Jaguar Limit Switch Not Working
I'm not too sure, but could it have been put into voltage ramping mode (turning the jumpers 90 degrees)? I'm not sure if these settings persist after a reboot without them actually having jumpers, though. Have you tried installing the jumpers the correct way for a limit switch, applying power, and seeing if it acts as expected?
I'm right 90% of the time, so why worry about the other 3%?
Unread 17-02-2014, 10:34
duane's Avatar
Thanks Cecil. That is the next step. We installed the jumpers to determine if that resets the jaguars. That was my reading of the specs as well.
Duane Murphy
Mentor - Software
Unread 17-02-2014, 11:39
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Yes, both limit switches removed at boot, disables limits and enables ramp mode. I think the idea was that at boot it did not make sense to be both at the positive and negative limits of travel. What are you trying to accomplish with the limit switches?
Unread 17-02-2014, 13:30
duane's Avatar
I would classify that as a non-feature.
The data sheet for the Jaguar says that installing the limit switches horizontally causes the ramp mode to be engaged.
Let me guess, horizontally is the equivalent of open. Doh!
Thanks. Grrrr.
Duane Murphy
Mentor - Software
