Information on PID Control
Currently, we are running CANBus mode on the jags without PID Speed control.
I've set up the PID Speed control and would like to know exactly what values to put where. I've heard that the "P" value is the only one that needs to be edited. So my question is; How are "P" values considered? Is it values between -1 and 1 or something else? |
Re: Information on PID Control
(P)roportional, (I)ntegral, (D)erivative. These are all terms of gain in the PID equation. Without getting into the math, I would try a .25 or .5 to start with with and then gradually increase (to speed up) or decrease (to slow down) from there.
For positional control, yes start with P and raise till unstable - back off and add some I to achieve closer final value.
For Velocity (Speed) control, many teams have had better success starting with I and adding P. The issue is with velocity, a negative proportional error will try to drive the motor backwards. The other way to solve this is to use a feed-forward term, which is not available on the Jaguar. |
Have you successfully implemented speed control using the PID algorithm in the Jaguars? Was it for the drivetrain, or some other mechanism? |
When you've actually successfully tuned a Jag PID for drivetrain speed control please post your experience here. This topic is of interest to many here on CD.
#7
Oh... Okay so I guess I'm pioneering the way for speed control PID? Because I really don't know what I'm doing with it.
#8
"Without getting into the math, I would try a .25 or .5 to start with with and then gradually increase (to speed up) or decrease (to slow down) from there."But when you are successful, please do share your experience. There are several threads on CD about tuning the Jag PID for speed control. If the built-in search in CD doesn't find them, try using Google with ... site:chiefdelphi.com Jaguar PID Last edited by Ether : 17-02-2014 at 16:08. Reason: i before e except after c... |
#9
we actually couldn't tweak it because we were busy rushing to finish the bot before midnight on bag day. I'll let you know after practice day at the San Diego Regional. ![]() |
#10
It proved way too glitchy for us to use.
We just said "screw it" and scrapped CANBus, because no other teams were dealing with CANBus and Labview, so we went back to PWM. Reminder to self, no more Mecanum drive. |
#11
That's unfortunate. We're using CAN and LabView and omni-wheels, but not with closed loop speed (yet). So far, we have not had problems, but we are using additional surrounding loops and filters on driver inputs and rotations to limit commanded speed changes.
In past years, we tried to start from the wheels up, and hit many frustrations. This year, we are starting from the top (driver) down, and doing better, although we have not closed the last loop at the jaguar to wheel. We noticed in the past that the Jaguars cut out when they seem to predict that they will exceed a limit, under PID control. We decided to filter the driver input by limiting the maximum acceleration allowed, both linear and rotational. Further, we implemented a PID in LabView to compare a modeled rotation to our gyro reading, and use that to drive the holonomic.vi rotational input. So far, this is the best control we've ever had for mechanum or omni-wheel. We would like to do the one last step of closing the loop at the wheel, now that we have more restrained inputs. That will have to wait until our bag gets opened later this week. In the end, we are good enough now, and have no issues with CAN Jaguars. |
#12
Len, Have you guys considered writing and posting a paper explaining what you've done? |
