Go to Post There are always rules we don't agree with, just like in life. Our character is defined by how we respond. - Mr MOE [more]
Unread 18-02-2014, 19:33
raptaconehs raptaconehs is offline
FRC #3200
raptaconehs will become famous soon enoughraptaconehs will become famous soon enough
Locking Controller in Driver Station
Currently our team uses one Xbox 360 controller and one 3-axis joystick. The Xbox controller is supposed to be recognized as the primary controller. When we were at scrimmage the driver station recognized the 3-axis controller as controller number 1 on the driver station which caused malfunctioning of the robot. Is there any way to lock the Xbox 360 controller as the number 1 controller on the driver station?
Unread 18-02-2014, 19:36
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Re: Locking Controller in Driver Station
I don't know if there is or not, but regardless, you can have a driver pre-match checklist that is taped to the laptop or driver station that includes checking that this is correct before every match. Might be a few other pre-match checklist items that you might want to add also... like say, pre-loading a ball. We forgot to do that in 2012 on our first match.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 18-02-2014, 19:45
We originally tried to use a USB hub and make the order match the hub ports. But USB has its own idea of how things get enumerated, and it rarely matches the ink on the case.
The typical joystick also doesn't have a serial number, so there is no way to identify a joystick uniquely and follow it from port to port. All we have is VID and PID -- vendor and product IDs. Many teams with multiple joysticks use the same model.
So in the end, we rely on the enumerate order of what is plugged in and we consistently index it. It is certainly a good idea to verify the joysticks are as expected. It should be pretty predictable, but if you randomly plug stuff in, it won't be, and the setup page is how you adjust it.
Greg McKaskle
