Go to Post if you've got the guts you will get the job done. - JamesCH95 [more]
Unread 18-02-2014, 23:18
4239 Mack 4239 Mack is offline
FRC #4239
4239 Mack is an unknown quantity at this point
Help with Encoder
We are using an encoder for the first time on our robot. Whenever we try to use it or declare it our robot doesnt work.
Encoder encoder = new Encoder(3, 4);
That is what we are using for the encoder and to get the values we are using.
encoder.get();
Can anyone help us set this up or provide a detailed tutorial for using an encoder in java?
EDIT: we have also tried using this.
Encoder encoder = new Encoder(3,4,false,EncodingType.k4x);
Unread 18-02-2014, 23:38
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Re: Help with Encoder
Can you give error outputs or describe what values you are getting from encoder.get()? your initialization of the encoder seems to be fine.
Unread 18-02-2014, 23:47
FRC #4239
We don't get any erros and the output we get is 0 no matter how much we rotate the pole its attached too
Unread 18-02-2014, 23:53
MichaelB MichaelB is offline
FRC #3573 (The Ohms)
MichaelB is an unknown quantity at this point
Between the first two bits of code you need to have encoder.start() somewhere.
