Go to Post Better is the enemy of good enough. - petek [more]
Unread 19-02-2014, 09:34
Ragingenferno's Avatar
Ragingenferno Ragingenferno is offline
That one guy
AKA: Josh
FRC #3053 (Stingers)
Ragingenferno is just really niceRagingenferno is just really niceRagingenferno is just really niceRagingenferno is just really niceRagingenferno is just really nice
Is this the correct way to move a motor forward then back in labview?
I'm trying to make a motor move forward then pause then go backwards all with one press of a button in lab view. I think I figured it out but i'm not to sure if I did it correctly.
Name:	Parallels Picture.png
Unread 19-02-2014, 10:28
Re: Is this the correct way to move a motor forward then back in labview?
Don't you want it to stop at the end?
What you have will work do something, but after the first button press the motor will always be left running.
The Flat Sequence Structure isn't normally done as three separate, individual structures.
Normal usage is to have a single Flat Sequence Structure, right click on a side edge and choose Add Frame After to add another frame.
Unread 19-02-2014, 11:30
nxtmonkeys's Avatar
nxtmonkeys nxtmonkeys is offline
SCP-682
AKA: Parker Wells
FRC #5349 (RoboEagles)
nxtmonkeys will become famous soon enough
To make a flat sequence structure, you right-click on the first panel and then a little windowish thing pops up. click on "add frame after" and you will have two frames.
Good Luck!
Unread 19-02-2014, 13:17
That one guy
AKA: Josh
Okay, I think i fixed it. Is it perfect now?
Name:	Parallels Picture 2.png
Unread 19-02-2014, 13:21
nxtmonkeys's Avatar
SCP-682
AKA: Parker Wells
It will work, but I was just told that sequence structures don't do well in teleop. I heard that they work best in the periodic tasks VI. Here is a pic of what it may also look like.
Unread 19-02-2014, 15:27
That one guy
AKA: Josh
Originally Posted by nxtmonkeys View Post
II heard that they work best in the periodic tasks VI.
Yes, I already have it in periodic task. Thanks for the example.
Originally Posted by Mark McLeod View Post
add a frame at the end to set the motor to 0 speed.
Now I got to add the 0 to the set output. Thanks.
Unread 19-02-2014, 16:43
nxtmonkeys's Avatar
SCP-682
AKA: Parker Wells
You are welcome.
Unread 19-02-2014, 14:19
Now it would run once, then never run again.
The Close should not be used.
Instead, add a frame at the end to set the motor to 0 speed.
Unread 19-02-2014, 14:23
nxtmonkeys's Avatar
SCP-682
AKA: Parker Wells
Mark is right.
