Go to Post When it was at 222, I was like 'Tigertrons from Tunkhahoohaasomethingconfusing Pennsylvania!' and my friend hit me for being such a loser. - Church [more]
Unread 20-02-2014, 10:54
CAPTIN_CAPSLOCK CAPTIN_CAPSLOCK is offline
Head Scout of FRC Team 1339
AKA: Christian
FRC #1339 (AngelBotics)
Team Role: Scout
CAPTIN_CAPSLOCK is an unknown quantity at this point
Question LEDs Operated by Arduinos: Awesome Cosmetics or Illegal Modifications?
My team is trying out a robot mounted light show this year, with LED strips operated by three Arduinos running along the frame of the robot in order to draw attention to all its majestic aluminum glory. The only problem is that the rules seem to be more or less ambiguous on this specific operation. So, I pose this question to you, Chief Delphi: can we do this legally, or are there limitations on our robot's cosmetic options?
Bonus points to anyone who can tell me if we can run all of our lights on one Arduino.
Unread 20-02-2014, 11:02
droswell's Avatar
droswell droswell is online now
FRC #2370 (iBots)
droswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to behold
Re: LEDs Operated by Arduinos: Awesome Cosmetics or Illegal Modifications?
What kind of LED strips? Addressable, or just a regular old RGB LED strip?
Unread 20-02-2014, 11:15
SteveGarward's Avatar
SteveGarward SteveGarward is offline
Red 5, standing by...
AKA: 7 years already
FRC #0111 (WildStang), FRC #3132 (Thunder Down Under)
SteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud of
We do this every year. It falls under a custom circuit. So long as you power and control it appropriately from the PD board according to the rules for custom circuits, you are fine.
Depending on the LED strips, you should be able to use a single Arduino to control them all, and not need 3 separate Arduinos.
FRC Team 111 - WildStang (Mentor, Drive Coach)
FTC Team 7458 - Full Force! (Mentor, Coach)
FRC Team 3132 - Australia's FIRST FRC Team! (Holy crazy first year, Batman!)
Unread 20-02-2014, 15:29
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Toa Circuit is an unknown quantity at this point
And if you custom make your own strips, and use Charlieplexing or shift registers, you can definitely control all the LEDs from one Arduino. Or even a mega, without charlieplexing or shift registers...
You might also be able to use the GPIO of the digital sidecar to run the lights. The DSC has PWM capability, though I don't know if the pullup resistors can be circumvented...
There's a lot of custom circuits you could make. We've got a trim-pot adjusted voltage regulator for our camera light ring, which is custom made of eight 10 degree viewing range LEDs. (Amazing power, no voltage drop even when the battery falls to 8 volts...)
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
Unread 20-02-2014, 15:48
rben13 rben13 is offline
FRC #1153 (Walpole Rebels)
rben13 is an unknown quantity at this point
You can use LEDs like these, http://www.adafruit.com/products/306, from Adafruit.com. They are controlled by one wire and Adafruit has already created the libraries you need. Be careful, though. The LED controller chips are very sensitive to static and reversed voltage. If you blow one, all the LEDs after it will be dark.
We plan on using an Arduino Mega 2560 to run our graphics this year, which will include LED strips and perhaps an LED panel.
Pay a lot of attention to how you're going to trigger the graphics. With the cRIO, you can use the RS232 port, I2C, or even dedicated GPIO lines that you raise to tell the Arduino which routine to trigger.
Hope this answer helps.
Ray
Unread 20-02-2014, 21:37
DonRotolo's Avatar
Back to humble
FRC #0832
Are they legal? Probably. Just avoid interfering with other robots' sensor systems. And don't make them blinding, please.
Hint: Look for a rule prohibiting it. If you don't find one, after a good look, then you are OK.
