Go to Post If this information is not 100% correct, you should follow the default advice I have for when anything goes wrong: Blame the Programmers - IKE [more]
Unread 21-02-2014, 19:08
astondis astondis is offline
FRC #4551
astondis is an unknown quantity at this point
Howto- Simulation in Solidworks
Is it possible to simulate Build Blitz's cam activated radial release mechanism in Solidworks? It can be a simulation or an animation.
Here's the JVN robot: http://www.youtube.com/watch?v=Gm96S8gdhR0
The purpose of this is to show judges and others at regionals on how the mechanism works.
Thank you.
Unread 21-02-2014, 20:26
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
Re: Howto- Simulation in Solidworks
There are three different types of animation/motion in SolidWorks
Animation and basic motion are in the bottom left tab.
To simulate the projectile motion, velocity, forces, you need to add in SolidWorks Motion.
BA SW created a video. http://www.chiefdelphi.com/forums/sh...d.php?t=125116
But to save time, I think basic motion would represent the cam rotation and the resulting lift. Look at the SolidWorks tutorial in Help. There is one on motion with a cam and another on simple animation.
While you are learning, copy the components into another folder. Simplify your model with only the components you need to define the animation. Suppress all fasteners. Marie
Unread 21-02-2014, 21:01
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Take a look at this model.
http://www.davyarcher.com/steam/
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 21-02-2014, 20:55
sailer99 sailer99 is offline
AKA: Sam
FRC #4476 (W.A.F.F.L.E.S.)
sailer99 has much to be proud ofsailer99 has much to be proud ofsailer99 has much to be proud ofsailer99 has much to be proud ofsailer99 has much to be proud ofsailer99 has much to be proud ofsailer99 has much to be proud ofsailer99 has much to be proud of
After playing around with trying to simulate this cam for a while this season I found it really depends how fancy you want to get with the animation/simulation. If you are fine with the release not being sprung forward and the cam being simply rotated by mouse you can use a limit angle mate between the first linkage bar and the rotating cam itself. This will simulate the motion quite well. If you want to see an example I can quickly make one up for you and send you the file.
edit- Attached an quick assembly of a cam, with the limit angle way of doing it if you turn the cam with your mouse it will work. However because of how it works it will only work if you turn it clockwise as the mate doesn't limit it properly turning counter-clockwise
Unread 22-02-2014, 21:55
FRC #4551
Thanks! I will play around with it and see what happens. Really appreciate the help
