Go to Post Most of the people who fit the profile of long tenured FIRST mentor are either already on a team or locked up in an institution where they belong... - PayneTrain [more]
Unread 23-02-2014, 17:21
ChewBacca's Avatar
ChewBacca ChewBacca is offline
FRC #0955 (Raiderbot)
Team Role: Animator
ChewBacca is an unknown quantity at this point
Rendering
I've run into a minor issue where 1/4 of our animation is going to take around 90 hours to render. Does anyone have any tips for either a. cutting down on render time (a lot) or b. a cheap online render farm that's easy to use?
-- Go Raiders!
Unread 23-02-2014, 17:40
Flimsor's Avatar
Flimsor Flimsor is offline
The Mad Cadder
FRC #1983 (Skunkworks Robotics)
Flimsor will become famous soon enough
Re: Rendering
Turning down the anti-aliasing and ray-tracing cuts down time significantly, but it will lower the quality of the picture. Of course, if you have access to a higher powered computer that helps too. I rendered a picture of my team's robot with all the quality options turned up in Autodesk Inventor on a computer with monstrous specs and it still took 5 and a half hours. I wish you luck!
- 2013
Thinking outside the box implies you have limited yourself in the first place.
Robots
Unread 23-02-2014, 17:42
ChewBacca's Avatar
Team Role: Animator
Re: Rendering
I disabled final gather, and I'm using a computer that I built specifically built for animation :/ I'll try turning off raytracing though.
-- Go Raiders!
Unread 23-02-2014, 17:43
Flimsor's Avatar
The Mad Cadder
Re: Rendering
There should also be options for different ray-tracing quality. We were also having problems with renderings taking too long, so we had to make a slightly lower quality version to give to our marketing team so they could have something to work with while the better one rendered.
- 2013
Robots
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
Re: Rendering
If the render software has a network render function, I'd be happy to throw it onto my machines.
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 23-02-2014, 17:46
ChewBacca's Avatar
Team Role: Animator
Re: Rendering
What do you mean by the network render function?
-- Go Raiders!
Unread 23-02-2014, 17:47
Nirvash's Avatar
AKA: Bryan
FRC #4676
Re: Rendering
Allows a head render node to give work out to slave nodes for processing.
So that the render can run on more then one server.
Unread 23-02-2014, 17:51
ChewBacca's Avatar
Team Role: Animator
Re: Rendering
Would you help me set that up? I have no idea how to. I looked it up and 3ds Max can do it, seems complicated though.
-- Go Raiders!
Unread 23-02-2014, 17:59
Nirvash's Avatar
AKA: Bryan
FRC #4676
Re: Rendering
From my quick readthrough of the docs, it doesn't look all too complicated. Do you have a lot of computers and want to set it up yourself? Otherwise the setup would be on my end. Also, what version of 3d Max are you using?
Unread 23-02-2014, 18:00
ChewBacca's Avatar
Team Role: Animator
Re: Rendering
I'm using 2014, I'm just using my desktop, but I have a server up right now. It probably would be better if it was on your end (If you have multiple computers), but would I be able to upload my files to it if it was your server?
Edit: Nevermind, it's really easy to add files from server or manager.
-- Go Raiders!
Unread 23-02-2014, 18:11
Nirvash's Avatar
AKA: Bryan
FRC #4676
Re: Rendering
I'm using 2014, I'm just using my desktop, but I have a server up right now. It probably would be better if it was on your end (If you have multiple computers), but would I be able to upload my files to it if it was your server? I also have a laptop sitting near me that I could connect in.
I could provide ftp details, or you could upload the project through a file sharing site. Just give me a little to spool up the render VMs and I can also give you a vnc address to access the server.
Also, do you have any IM details that would probably be more suited for conversation? (You can PM me them)
Unread 23-02-2014, 23:43
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Rendering
We have set up a Backburner render farm of about 40 quad core i5 slaves to do our 3DS renderings. Works awesome. We could probably run it for you if you sent us the project. How big is that file?
