Thread Tools |
Rating:
Display Modes |
automatic IP FRC team changer by:CFR #4966
Hi:
My name is camilo, from condor force robot (Chile). We created a application that change the ip of your team for connect to the crio automatically, without enter to control panel, and network configuration.This application decreases the work of configuring your ip every moment that you want connect to the robot,it's more quickly. Application only runs in windows 7 and windows 8. download here PD: any problem, contact to cbastias@condorforcerobot.cl thanks. atte Camilo Bastias #4966 Condor Force robot Last edited by Cbastias4966 : 24-02-2014 at 14:58. |
Re: automatic IP FRC team changer by:CFR #4966
You could just write a batch script for that.
netsh interface ip set address "<interface name>" static <addr> <netmask> <gateway> netsh interface ip set dns "<interface name>" static <dns_addr> Alex Brinister |
the driver station already does it as well i believe
The driver station checks the IP info -- using netsh. If it doesn't meet the expected settings, it will set it to a static IP.
It does not automatically restore the settings, but it does create a restore file and script in the Public Documents directory named "FRC Restore My Network Settings.bat". You could pretty easily put an alias to it on the desktop. Greg McKaskle |
The script the driver station uses doesn't revert the IP settings back to dhcp as far as I remember, you'd have to make that part with your own batch file. Its a pretty simple command though:
netsh interface ip set address "<your internet name>" dhcp I think thats right. My sleep schedule has been wrecked lately but I think that't it. ![]() |
#7
If the DS changes the IP settings, it performs a dump to a text file. It doesn't explicitly set the PC to DHCP, but attempts to restore it to how it initially found it. Originally, it was going to restore when quitting, but this was actually quite annoying, especially on a programming laptop. This step needed to be independent of the DS.
Below is the documentation on dump. I haven't used it in years. Greg McKaskle C:\Windows\system32>netsh interface ip dump /? Usage: dump Remarks: Creates a script that contains the current configuration. If saved to a file, this script can be used to restore altered configuration settings. |
