Go to Post Starting from scratch is what makes it hard. - ChrisH [more]
Unread 24-02-2014, 23:03
ayang548 ayang548 is offline
FRC #3663
ayang548 is an unknown quantity at this point
Apparent Infinite Loop When Calling AxisCamera.getInstance()
We have a stripped down version of 2014VisionImageSample Project that is apparently going into an infinite loop when it reaches the AxisCamera.getInstance() call. This is our code:
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.camera.AxisCamera;
public class VisionSampleProject2014 extends SimpleRobot {
AxisCamera camera;
public void robotInit() {
System.out.println("about to be initialized... the camera");
camera = AxisCamera.getInstance();
System.out.println("camera initialization complete");
public void autonomous() {
public void operatorControl() {
When the call to AxisCamera.getInstance is made, we can trace the code into the constructor using the debugger.
When cameraStartFn.call1 is called, it never returns (this code is inside AxisCamera.java inside WPILIB)
* Axis camera constructor that calls the C++ library to actually create the instance.
* @param IPAddress
AxisCamera(String IPAddress) {
Pointer ptr = Pointer.createStringBuffer(IPAddress);
cameraStartFn.call1(ptr);
Our camera IP address is 10.36.63.100
So when we run the code above we expect to not find the camera because the default address is 10.36.63.11. The code does not find the camera as expected but it never returns and repeats the following error message.
Debugger output with incorrect camera IP address
Established connection to Debugger (handshake took 32700ms)
### Excluding compile: com.sun.squawk.SymbolParser::getSignatureTypeAt
### Excluding compile: com.sun.squawk.Method::getParameterTypes
[cRIO] about to be initialized... the camera
[cRIO] JavaCameraLib was compiled from SVN revision 2962
[cRIO] camera initialization complete
[cRIO] Default disabled() method running, consider providing your own
[cRIO]
[cRIO]
[cRIO] >>>>ERROR: S_errno_EINPROGRESS (0x00000044): Failed to connect to the camera ...in CreateCameraSocket() in C:/WindRiver/workspace/WPILib/Vision/AxisCameraParams.cpp at line 457
[cRIO]
[cRIO]
[cRIO]
<Error Messages repeat apparently forever>
When we pass in the correct IP address, the error messages go away but the call still never returns.
camera = AxisCamera.getInstance("10.36.63.100");
Debugger output with correct camera IP address
Established connection to Debugger (handshake took 2315ms)
Attached JPDA debugger to localhost:2900
<Output stops>
We've repeated this with 2 different cameras and 3 different computers. Does anyone have an idea what is wrong?
Thanks,
Angelique
Unread 25-02-2014, 13:33
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
Re: Apparent Infinite Loop When Calling AxisCamera.getInstance()
Just using a webbrower can you connect to the camera from the driverstation?
Is the camera set to enable anonymous viewing?
I don't use the WPI libraries to access the camera, but if I recall correctly, in the past (2011, 2012) the WPI library used to take about 10-12 seconds to initalize a connection to the camera, and it would block robot functionality while this was being done.
I am not sure, if this has been fixed or rectified in recent versions of WPILib.
What if you reset your camera to the default IPgiven to it using the axis camera tool. Does the code work then?
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
Unread 25-02-2014, 13:54
RedDog RedDog is offline
AKA: Brian King
FRC #3663 (Cedar Park Robotics)
RedDog is an unknown quantity at this point
[I am Angelique's mentor]
Yes, the camera image display's fine in the DS and when browsing directly. And anonymous viewing/login is enabled.
We will try moving the camera's IP to the default tonight.
Thanks for the suggestion
Brian
Unread 25-02-2014, 15:38
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
Have you created an an account with the username and password "FRC"?
Unread 25-02-2014, 20:17
FRC #3663
Talking Re: Apparent Infinite Loop When Calling AxisCamera.getInstance()
We moved it to the default IP address and added the FRC account and somewhere along those lines, it worked!!! Thanks for your help!
-Angelique
Unread 25-02-2014, 22:57
Controls Engineer
AKA: Kevin
great!
