Go to Post So take it all with a grain of salt, form your own opinions, lead by example, act responsibly, be graciously professional, and everything will be ok. - LauraN [more]
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Unread 25-02-2014, 18:13
Colin Small Colin Small is offline
FRC #0114 (Eagle Strike)
Team Role: CAD
Colin Small is an unknown quantity at this point
RangeFinders: IR vs. Ultrasonic
We're looking for a rangefinder for our robot for use for getting the right distance from the wall to shoot from. Now, I've done some research and found that the IR sensors are good when you have no ambient light (which would be the case indoors in the stadium) and Ultrasonic are more accurate. More accurate would be better, and I've been having troubles locating a good IR sensor that's no too expensive that gives us a minimum range of around 20 feet. As far as utlrasonic goes, we found the Maxbotics MB1240, it looked like it would work great. Unfortunately, we don't know if we should go with an IR sensor in fears of interference from the Ultrasonic Sensor (other than other robots, I can't think of other possible causes for interference).
Unread 25-02-2014, 18:20
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: RangeFinders: IR vs. Ultrasonic
For long distances (more than 3ft or so) most teams have used Ultrasonic sensors for FRC applications.
Unread 25-02-2014, 20:50
mman1506's Avatar
mman1506 mman1506 is online now
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
The (sharp?) IR sensors are fairly outdated tech, the maxbotix sensors are much more resistant to interference and accurate than a IR sensor.
2016: FRC 865 Mentor
2017: Free Agent Mentor, Ref, Inspector
Unread 26-02-2014, 14:24
Team Role: CAD
Then the MB1240 is what we'll go with. Can you angle them upwards to try to avoid our bumpers (due to our design layout; a rangefinder wasn't in our original design)? Sound isn't a strait line, so wouldn't it mess up the sensor if you don't have it flat?
Unread 26-02-2014, 15:52
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
Look up the data sheet for the MB1240 and you'll find it has a very narrow beam angle. In fact, it's the most narrow of any of their sensors. What that means is if it isn't aimed right at the wall you'll get very little signal back.
The angle of incidence = the angle of reflection, and all that.
Unread 27-02-2014, 16:48
Team Role: CAD
I know, but all it's going to be used for is to aim at the wall. That's the reason I chose the MB1240. I don't want interference from other robots.
