Go to Post Never thought I would have a world championship type event within a 15 minute drive of my house. - Jay O'Donnell [more]
Unread 27-02-2014, 15:30
TogetherSword8 TogetherSword8 is offline
FRC #0888 (Robotiators)
TogetherSword8 is an unknown quantity at this point
Breaking mounts of Encoders on Andymark Super Shifter
This year we got new andymark supershifters, and bought 4 for our two robots that we build. In the past two days, we began to run the practice robot a lot, and we have broken both mounts for the encoders that come pre-installed on the robot.
We have diagnosed the problem that when we shift gears, the bearing at the end of the shaft pushes on the encoder mount, and the shifting of gears causes the mount to split.
Has anyone had this problem before, and if so, how did they fix it? We have some ideas of our own, but would rather not mess around with an idea we have if it is a problem that has been solved before.
I program a robot. Which means I write code and everyone gets mad at me when something doesn't work, even if I am the only one that knows it doesn't work. The key part to know is that the robot never works.
Unread 27-02-2014, 15:46
Bruceb's Avatar
Bruceb Bruceb is online now
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Re: Breaking mounts of Encoders on Andymark Super Shifter
you are breaking the mount? It is aluminum that is like a quarter inch thick?
Or are you talking about the encoder itself?
We have used the same super shifters for years (changed gear ratios this year) and have never broken the incoder much less the mount.
Got a pic?
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 27-02-2014, 15:47
We are breaking the plastic mount that then encoder attaches to. Ill attach a picture in a little bit when we are done working on something else.
Unread 27-02-2014, 16:00
Here is a picture of what we broke. This is the plastic mount that holds the encoder on. This is under the mount for the chip, which is under the chip, which is under the disc, which is under the outer case that snaps into the mount for the chip. It is the actual part you use to mount the encoder to the plate.
The picture shows the main part that came off, but the top is also cracked, with obvious signs of the center getting pushed out.
Unread 27-02-2014, 16:01
Bruceb's Avatar
we just screw the encoder on the servo mount bracket that comes with the supershifter. It has holes in it for the encoder.
Unread 27-02-2014, 16:10
Sorry, but the mentor and i had some miscommunication. We are actually using the AM shifter that is here:
http://www.andymark.com/product-p/am-0957.htm
Unread 27-02-2014, 16:19
Bruceb's Avatar
Ah OK I dont have any experience with that
Sorry
Unread 27-02-2014, 16:38
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
It's hard to tell from the photo you posted, but, it looks like you have the encoder bracket mounted inside out.
It should be mounted such that the "cut around" in the plastic bracket sits over the bearing in the gearbox, and it should be flat on the side you screw the encoder on to. Try flipping it 180 degrees along the horizontal plane.
That's the best I can make out from the photo.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 27-02-2014, 16:44
404'd's Avatar
404'd 404'd is offline
Lead contributor of sweg
AKA: Josh
FRC #0967 (Iron Lions (9-sits-7))
404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all
From what I can tell from the picture I believe they have it installed correctly. Itd be pretty hard to install it flipped like you're saying.
Driving "Career":
2012 GKC: Quarterfinals w/ 6th seeded alliance | Wisconsin: Quarterfinals - 3rd seeded alliance captains
2013 GKC: Quarterfinals w/ 5th seeded alliance | North Star: Regional winners, 2nd seeded alliance captains
2013 CMP: Curie Semis w/ 2056 + 3990
Unread 27-02-2014, 18:15
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
I also think that it is mounted backwards. If those are the encoders I think they are you want to have most of the encoder sitting above the screws not below them.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 27-02-2014, 18:35
cglrcng cglrcng is offline
FRC #0060
cglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond repute
Did you follow the instructions listed here under "How To Pictures" tab at the link you provided for the AM Shifter at Andy Mark? Aligning the disk clips at the very end of the back of the hex output shaft. Means you would not use the alignment tool usually provided w/ the encoder I would think.
Or are there spring clips missing from the hex end of the output shaft on the other side allowing the output shaft to back out the other side? (The ewncoder side). We usually cut the shafts for clips on the wheel side ourselves.
http://www.andymark.com/product-p/am-0957.htm Click on the tab below it marked "How To Pictures."
Good Luck!
(After a much closer review of both the Docs and the How To Pics there at the Andy Mark Link above....Something is definitely wrong...The Docs and the pics do not even match...I'd contact Andy Mark ASAP). The installation shows 180 degrees different in exactly how those should even be mounted according to the Docs and How To Pics.
Looking again, the completed pic at that link showing the whole (am-0957) for sale...NOTE: Use the magnifier on the pic...It shows no encoder enclosure cover on that completed encoder...Just the wheel clips lined up w/ the end of that shaft. So, maybe you cannot put the normal encoder cover on w/ those particular shifter gearboxes. (they do work without the cover...That I do know. If a cover is snapped on and that shaft floats outward, it would break that mount. I'm sure if a cover was supposed to be attached, that completed gearbox pic would show it attached. Did you have a cover attached to the encoder that broke the mounts? The How To Pics don't show a cover either...But I wouldn't think they would given that all they are trying to show there is the alignment of the encoder wheel clips to shaft end.
Unread 28-02-2014, 07:59
How is the bearing being pushed far enough out to damage the encoder mount? Is the bearing itself perhaps installed backwards, with the flange on the outside of the gearbox case instead of the inside?
