Go to Post The best metrics are your own. Do you see the impact of your efforts in your community? Do you feel like you should/could have won Chairman's, but another team was even more deserving? That's how you know FIRST is really working. - dcarr [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Thread Tools Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Unread 04-03-2014, 11:47
World Rankings 2014
I calculated the rankings of all teams using the FRC District Standard Points Ranking System as shown below. Since everyone does not have a standardized 2 events per team or 12 matches per event, I made the following modifications: Win points are normalized based on 12 matches per event. The first two events are counted. If a team has participated in less then 2 events, their first event is doubled (as a result, every team has their points doubled this week).
POINT CATEGORY POINTS 					POINTS
Win-Loss Record in Qualifying Rounds
Win 							2
Tie 							1
Loss							0
Alliance Selection Results
Alliance Captain				        Equal to 17 minus the Alliance Captain Number [e.g.: 14 points for Alliance #3 Captain]
Draft Order by Acceptance  				Equal to 17 minus the Draft Order Acceptance Number [e.g.: 12 points for the Team that is 5 th to accept an offer of Alliance]
Elimination Round Performance 				5 points for every match won in which a Team ’s robot participated,
Awards
Chairman’s Award				        10 Points for
Engineering Inspiration and Rookie All Star Awards      8 Points
all other judged Team awards				5 points
Team Age
Rookie Teams 						10
Second-year Teams 					5
Here are the top 25. Full rankings are attached. The full rankings show all factors, as well as the rankings without normalizing for matches or number of events.
Rank	Team	Events	Points
1	624	1	170
2	33	1	156
3	1310	1	152
4	1986	1	152
5	399	1	152
6	3824	1	150
7	118	1	150
8	138	1	150
9	1678	1	150
10	525	1	146
11	2590	1	142
12	2046	1	142
13	610	1	140
14	2907	1	140
15	75	1	140
16	107	1	138
17	1261	1	130
18	177	1	126
19	3393	1	126
20	1403	1	126
21	341	1	124
22	2468	1	124
23	294	1	120
24	2557	1	118
25	1241	1	118
I have compared the results with the FiM, MAR, and PNW rankings, and they agree. I used Ed Law's standings for Centerline.
Unread 04-03-2014, 12:52
Citrus Dad's Avatar
Citrus Dad Citrus Dad is offline
Business and Scouting Mentor
AKA: Richard McCann
FRC #1678 (Citrus Circuits)
Citrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond repute
Re: World Rankings 2014
Since this system may be instituted for all District events in the future, it's worth discussing this calculation. Several thoughts:
- Since this is a World Ranking (which has no real consequence) vs District qualifying (which needs to have clear, fair and balanced rules), I think you should use the LAST 2 events to reflect how a team evolves during the season and best reflects how they are doing going into the Champs. (I understand why Districts uses the first 2 events and agree with that.)
- Losses in elimination rounds should count against a team, say -1.
- Also, later wins should gain more wait, beyond simply 5 more points. This will give a bigger distinction for teams that make it to the finals, more than just 5 more points. Winning an overall event should be worth much more than winning 100% of the matches (e.g. 24 points for going 12-0 vs 30 points for winning the Regional.) Probably should aim for winning the regional to be worth 48 points instead (double winning the qualifying rounds). Scoring 6 points for quarters, 8 points for semis and 10 points for finals would do that.
- Finally, you should normalize on a non-integer basis as a percentage. It's more difficult to win more matches in a longer tourney because of the abuse of the robots, but the current scaling doesn't give full credit for that.
Unread 11-03-2014, 14:40
If I was trying to do rankings that reflected teams going into champs, I would not be using anything close to this system. Instead, this is a way for teams not in districts to see how they stack up. The word rankings is simply because that is what Michigan uses.
Normalization on non-integer basis has the effect of number of matches acting as the first sorting criteria. When I first starting playing with California rankings last year, I did play around with integer and non-integer normalization (as well as no normalization). I was much happier with integer normalization.
These are probably better discussed either at http://www.chiefdelphi.com/forums/sh...d.php?t=121132 or http://www.chiefdelphi.com/forums/sh...d.php?t=121362
Unread 11-03-2014, 14:57
Clinton Bolinger's Avatar
Clinton Bolinger Clinton Bolinger is offline
FF - PureMichigan
FRC #2337 (EngiNERDs)
Clinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond repute
Joe,
Do you plan to release Week 2's Results?
Thanks for putting this together.
-Clinton-
Unread 11-03-2014, 15:27
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Just checking to make sure I followed what Joe Did
So I really want to Normalize for number of events played, and for the size of certain events. Its not fair to compare a smaller, 30 team district with a with a 42 team district with a 58 team 3 day regional.
My idea: separate out these different categories as appropriate. Qualification wins is pretty self explanatory, it should normalize for the number of chance you have for a win. The middle section of the formula should be adjusted for the number of times you get to be picked, judged and play in eliminations. The last section should only be awarded once per season *before district champs*, I'm open to suggestions, especially for the last segment of the formula.
My Proposed Formula, point values follow District Standard Points Ranking, hopefully it lines up with Joe's.
Normalized World Rankings=
[(Qualification Wins + Qualification Ties) / (Qualification Matches Played)]
[(Alliance Captains + Draft Order Acceptance + Elimination Performance + Judged Awards) / (Number of Events Participated In)]
[Team Age + Chairman's + Engineering Inspiration + Rookie All Star]
Edit: I completely realize this makes it really difficult to figure out ties. Probably should just prioritize the second part of the formula.
Last edited by Conor Ryan : 11-03-2014 at 15:38. Reason: reading joe's spreadsheet
Unread 11-03-2014, 16:24
Yes, I'm error checking and formatting the results.
Originally Posted by Conor Ryan View Post
J
It's close to what I do.
Round[((Qualification Wins + Qualification Ties) of first 2 events) / (Qualification Matches Played in first 2 events) * 24]
[(Alliance Captains + Draft Order Acceptance + Elimination Performance + Judged Awards) of first 2 events / Min(Number of Events Participated In,2)*2]
[Team Age + (Chairman's + Engineering Inspiration + Rookie All Star) of first 2 events]
Unread 11-03-2014, 17:36
Here are the top 25 after week 2. I've attached the full spreadsheet.
1	624	1	170
2	4488	1	161
3	33	1	156
4	2175	1	156
5	1817	1	156
6	4967	1	156
7	1310	1	152
8	2337	1	152
9	1986	1	152
10	399	1	152
11	3824	1	150
12	118	1	150
13	138	1	150
14	1678	1	150
15	1108	1	150
16	525	1	146
17	254	1	146
18	16	1	146
19	3467	1	144
20	4911	1	144
21	2590	1	142
22	2471	1	142
23	2046	1	142
24	1266	1	142
25	2468	2	141
Unread 11-03-2014, 19:07
Tyler2517's Avatar
Tyler2517 Tyler2517 is offline
ShortOnes
AKA: Tyler Gibb
FRC #2517 (Evergreen Robotics)
Tyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura about
It makes me happy seeing a second year team in 2nd place.
Unread 11-03-2014, 19:12
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Wow top 20 after some teams we look up to every year!
1058 PVC Pirates 2016 - xxxx
Unread 13-03-2014, 10:30
Tim Lehmann4967's Avatar
Tim Lehmann4967 Tim Lehmann4967 is offline
A Sentient Being
FRC #4967 (That O.N.E Team (Our Next Engineers))
Tim Lehmann4967 will become famous soon enough
It is really cool to see our team number on that list in our rookie season!
Unread 13-03-2014, 11:38
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
I am doing something similar to score the Ohio teams for our State Event this year. Question on your week 2 results. 4269 came into Q3-3 as a back up bot at Crossroads, won 5 matches, why do they not have any elimination points?
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 13-03-2014, 16:34
I have to correct backup teams points manually. I remember doing that for 5188 and 4269, but probably overwrote those values when fixing something else. Attached are corrected rankings.
Unread 14-03-2014, 06:42
Mentor,QCR Planning
Thanks!
Unread 11-03-2014, 20:23
Citrus Dad's Avatar
AKA: Richard McCann
So this is better described as "World District Scoring" rather than "Ranking" since it's not really relevant to non-District teams?
Unread 11-03-2014, 20:27
Boe's Avatar
Boe Boe is online now
2175 Alum
AKA: Brian Boehm
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
Wow tied for third, I didn't think I'd ever see my team so high on some type of FIRST wide ranking.
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
