Go to Post When you do something great, it just feels good. - tiffany34990 [more]
Unread 08-03-2014, 20:46
Week2 cumulative Twitter stats & OPRs
Stats and OPRs based on Twitter Qual match data as of Sat 3-8-14 20:05:49 ET.
The usual Twitter data caveats apply.
NOTE: Look for updated data in more recent posts in this thread
Unread 09-03-2014, 15:09
Re: Week2 cumulative Twitter stats & OPRs
Stats and OPRs based on Twitter Qual match data as of Sun 3-9-14 14:54:20 ET.
The usual Twitter data caveats apply: Twitter data is incomplete and may contain errors and redundant data. Twitter data is not official. However, it contains information not available in the official Match Results and Team Standings data, such as foul points for each match.
Explanation of "Quartile" for those not familiar with the term:
Example:
win final score:
     102 average (mean)
     420 max
     131 Quartile3
      95 Quartile2
      67 Quartile1
100% of the winning scores were less than or equal to 420
 75% of the winning scores were less than or equal to 131
 50% of the winning scores were less than or equal to  95
 25% of the winning scores were less than or equal to  67
 25% of the winning scores were between 131 and 420
 50% of the winning scores were between  95 and 420
 75% of the winning scores were between  67 and 420
Unread 09-03-2014, 22:57
Elim Stats based on Twitter Elim match data as of Sun 3-9-14 14 20:03:13 ET.
See previous post for Qual stats and OPRs.
The usual Twitter data caveats* apply.
* Twitter data is incomplete and may contain errors and redundant data. Twitter data is not official. However, it contains information not available in the official Match Results and Team Standings data, such as foul points for each match.
Unread 09-03-2014, 23:59
For comparison, here's the combined final score OPR using the official FRC MatchResults data (not Twitter) for Week1+Week2.
File Type: xls OPR based on MatchResults data for Weeks 1 & 2.xls (107.0 KB, 88 views)
Last edited by Ether : 10-03-2014 at 12:34. Reason: spreadsheet updated to include TXSA
Unread 10-03-2014, 11:29
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
It appears team 2386 is missing from your list?
Edit: It looks like you're missing the entire Alamo regional
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 10-03-2014, 11:54
Good catch. A file was missing from the folder when I ran the script. I'll post a correction shortly.
Edit:
Update posted.
According to the log file created by my script which processed the MatchResults data there were a total of 2124 qual matches and 1112 teams at 26 events in weeks 1 & 2.
Compare that to the Twitter data for weeks 1 & 2: only 1822 qual matches and 994 teams.
Unread 10-03-2014, 15:19
Here's a spreadsheet of the "OPR" of all the data columns for all the Qual matches in the Twitter data as of Sun Mar9 20:03:13.
"OPR" (least squares fit) was computed for each team not only for their alliance scores, but also for their opponent's alliance scores.
So for example:
column B minus column F gives the CCWM
column B minus column C gives the "unpenalized score"
(B-C) - (F-G) gives the "unpenalized CCWM"
You can add whatever other computations might interest you.
File Type: xls Twitter Qual Match all-columns OPR Mar9 200313 data.xls (282.0 KB, 117 views)
Unread 12-03-2014, 16:27
See attached plot of A∙x-b alliance unpenalized score residuals vs percent of alliance scores, taken from Twitter data dated Sun Mar9 20:03:13 ET containing 1822 Qual Matches with 944 Teams.
A∙x~b, where:
A is the binary design matrix of the alliances;
x is the Team unpenalized OPR* score vector;
A∙x is the alliance unpenalized OPR* score vector;
b is the alliance unpenalized actual score vector;
A∙x-b is the residual vector (difference between A∙x and b)
From the graph you can see that 65% of alliance scores are within ±20 unpenalized points of the OPR. 37% are within ±10 points.
*L2 norm (least squares) solution of A∙x~b
Name:	unpenalized score residuals.png
Unread 12-03-2014, 19:14
MrRiedemanJACC MrRiedemanJACC is offline
FRC #2611 (Jacktown Vectors)
MrRiedemanJACC will become famous soon enough
Per our previous conversation, I am assuming most teams from Gull Lake aren't represented very well in this because of the lack of twitter data? (I'm thinking 2054 should be pretty far up there on OPR)
Unread 12-03-2014, 19:36
What does the pronoun "this" refer to? Your post is linked to Post8, which does not show individual team OPRs at all.
Unread 12-03-2014, 20:18
Robotmmm Robotmmm is offline
Robotmmm has a brilliant futureRobotmmm has a brilliant futureRobotmmm has a brilliant futureRobotmmm has a brilliant futureRobotmmm has a brilliant futureRobotmmm has a brilliant futureRobotmmm has a brilliant futureRobotmmm has a brilliant futureRobotmmm has a brilliant futureRobotmmm has a brilliant futureRobotmmm has a brilliant future
Is there a way to denote that teams that attended week 1 Mount Olive District had matches played that were 20 seconds short?
