I NEED AN ANSWER!!! EVERYONE READ!
Posted by Rob DeCotiis at 2/17/2001 9:18 AM EST
Student on team #504, RoBUCtics, from Red Bank Regional High School and Jesel. Can we use an angle bracket that's 4"?? would that be considered a joining plate for an extrusion or would it fall under steel angle in the additional hardware list??? |
Re: I NEED AN ANSWER!!! EVERYONE READ!
Posted by Elgin C at 2/17/2001 10:56 AM EST
Engineer on team #237, Sie-H20-Bots, from Watertown High School / NVCC. In Reply to: I NEED AN ANSWER!!! EVERYONE READ! Posted by Rob DeCotiis on 2/17/2001 9:18 AM EST: : Can we use an angle bracket that's 4"?? would that be considered a joining plate for an extrusion or would it fall under steel angle in the additional hardware list??? There are limits on the size of angle you can use. It is somewhere in the Adittional Hardware list. Hope that helps. |
angles... only up to 2" x 2"
Posted by Ken Leung at 2/17/2001 12:42 PM EST
Student on team #192, Gunn Robotics Team, from Henry M. Gunn Senior High School. In Reply to: I NEED AN ANSWER!!! EVERYONE READ! Posted by Rob DeCotiis on 2/17/2001 9:18 AM EST: : Can we use an angle bracket that's 4"?? would that be considered a joining plate for an extrusion or would it fall under steel angle in the additional hardware list??? If you did not physically join the plates together to form angle bracket (like welding them together), then yes, it falls under steel angle in the additional hardware list. But if you are using 1/4" thick steel and bend it into angle bracket, that that will fall under steel plate (any amount). Please try to make sure you don't actually use the 4" x 4" steel angle bracket and claim them as manufactured from steel plates if you actually didn't. |
| Robot/Goal scoring: Official Answer Mike Martus | Mike Martus | OCCRA | 6 | 21-10-2003 23:51 |
| read and write command | rosebud | Programming | 3 | 26-03-2003 19:44 |
| Read the Rules! | Gadget470 | General Forum | 13 | 09-01-2003 13:58 |
| Marking forums read | David Kelly | CD Forum Support | 6 | 15-05-2002 14:50 |
| 'read' posts that arent read | mike o'leary | CD Forum Support | 4 | 10-06-2001 11:29 |
