Cim Motor Help
We are having problem with a Cim motor it will go one direction, but when we use our toggle to go the other way it just makes a clicking noise and wont move. Any Suggestions?
Re: Cim Motor Help
is it the moter making the noise, or whatever is attached to it?
Re: Cim Motor Help
The Motor as if its trying to move but can't.
Re: Cim Motor Help
Is there anything attached to the motor's output shaft? If so, please provide some pictures/description of what it is.
Re: Cim Motor Help
We have a belt attached and it runs a set of wheels for the robot. ill try to get a picture up.
Re: Cim Motor Help
i wouldn't run the cim, you may have damaged some internals, i would try taking it apart to inspect, there could be metal bits inside, but i haven't a clue. that is really the limit of my knowlage. (this was before i knew about the wheels attached only do this if your cim is doing this not attached to anything)
#7
Re: Cim Motor Help
the thing its driving, can you rotate it manually in the direction it needs to go? if not then find out whats blocking it
#8
Re: Cim Motor Help
What are you using to drive the motor? We have had half an H-Bridge on the speed controller fail which then can drive only one direction. Does it drive the opposite direction if you swap the motor leads to the speed controller? Does it work connected directly to the battery?
Also, if you are using Jaguar, it has two limit switch inputs that can keep it from running in one direction - although that should not make noise. Check the limit switch jumpers anyway. Does the speed controller LED color change to indicate you are commanding both directions? Red, yellow green? Last edited by gpetilli : 13-03-2014 at 12:14. |
#9
Re: Cim Motor Help
Or, have you tried putting 12V directly to the motor yet (without going through a speed controller)? If you're confident the motor should be able to go in the "down" direction, we usually just put 12V directly to the motor in order to test the mechanisms. We have a setup we use where we can plug in a 12V battery and also connect motor leads (with 'gator clips) that uses a momentary switch to energize the clips so that we can test mechanisms before we have the control systems completed. -Danny |
#10
Re: Cim Motor Help
Re: Cim Motor Help
Depending on the speed controllers used, the issue could be improper calibration and/or them not being calibrated at all. IIRC, Talon's ship without being calibrated, but I'm unsure of both Jags and Victors, although it wouldn't surprise me if the calibration were off... If the calibration is off, your zero may not actually be zero, it could be some amount in either direction from there, meaning that when you give a signal in the opposite direction, it might not be able to overcome the resistance on the motor since it'll only be at partial output - we actually had this exact problem at our first event, and it's a weird one to chase. |
#12
Re: Cim Motor Help
Try taking the motor out of the drive system and testing the motor with no load on it.
Using a power supply, apply a small voltage (9V) and determine if the motor shaft rotates. Flip polarity between motor leads and re-test. This will determine if the motor itself is the problem. Do not take the CIM apart - it isn't necessary to determine if it is functional or not. I expect the CIM is probably good, because it runs in one direction, but not the other. That would point to a speed control, or potentially a programming issue. You should also try swapping drivers controllers too, just in case the joystick or whatever, isnt working properly. If you don't want to or cannot get the CIM out by itself, then get the robot off the floor and determine if there is a mechanical back drive issue by rotating the wheels by hand. If the wheels do not move, check the rest of the drive train for anything that might be interfering with the whatever is driving the system (chain, belt, etc). The CIM motor output shaft should rotate freely in both clockwise and counter-clockwise directions. It isn't like the window lift motor, that doesn't allow it to backdrive freely. Hope this helps, Mike |
