Go to Post Looks very well designed. Now where is the "export to reality" button in the CAD software? (I have been looking for it for weeks). - sanddrag [more]
Unread 24-06-2002, 01:02
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Y-cables and switches
Posted by EJ at 2/18/2001 1:46 PM EST
Student on team #254, Cheesy Poofs, from Bellarmine.
Can ne 1 tell me y when a joystick and a switch are connected to the y-cable, which is connected to port 1, that when the joystick (that is connected to the y-cable) is on full forward and the a joystick (connected to port 2) is on full reverse that the switch looses voltage? if u have ne advice to offer it would be greatly appreciated
#0047 (ChiefDelphi)
Re: Y-cables and switches
Posted by Nate Smith at 2/18/2001 3:13 PM EST
Other on team #66, Frostbite, from Willow Run High School and GM Powertrain.
In Reply to: Y-cables and switches
Posted by EJ on 2/18/2001 1:46 PM EST:
: Can ne 1 tell me y when a joystick and a switch are connected to the y-cable, which is connected to port 1, that when the joystick (that is connected to the y-cable) is on full forward and the a joystick (connected to port 2) is on full reverse that the switch looses voltage? if u have ne advice to offer it would be greatly appreciated
Just out of curiosity, which digital input on the OI do you have the switch(connected to the Y-cable) hooked to? Looking over the control system manual, I don't see anything that should interfere between ports 1 and 2, but just to be safe, do you have an open pin on ports 3 or 4 you could hook the switch to? That might help...
Nate
[IMG] code is Off
maximum length of joystick cables archiver 2001 2 23-06-2002 23:54
