Go to Post IRI: where egos go to die...uhm..I mean fly! - Koko Ed [more]
Unread 14-03-2014, 15:23
2544HCRC's Avatar
2544HCRC 2544HCRC is offline
FRC #2544 (HCRC)
2544HCRC has a spectacular aura about2544HCRC has a spectacular aura about2544HCRC has a spectacular aura about
Mounting compressor upside down
We are mounting our compressor upside down this year under the robot. In final testing we weren't getting the pressure up above about 80 psi from the compressor. I was wondering if other teams have done this? It very well could be a poorly adjusted safety valve. This was not checked and we frankly didn't think of it until after it was in the bag. Mostly I'm looking for a "we mount them that way all the time" or a "you can't mount it that way because..." And it is the Viair compressor. Just trying to think of things that need to be done on the first day of the competition...
Thanks!
Unread 14-03-2014, 15:24
Thad House Thad House is online now
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Re: Mounting compressor upside down
Last year we mounted our compressor upside down. That should be fine. It most likely is caused by a leak, or an issue with the pressure relief valve.
Team 4488 - Mentor 2013-2016
Unread 14-03-2014, 16:00
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
If you can prove to the inspector that your mounting is safe, you are fine. There are no rules that otherwise specify an orientation for mounting the compressor.
Unread 14-03-2014, 17:58
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
It is probably caused by some sort if leak in your air system.
How much storage are you using?
Also I assume you know that you may store air at 120 psi and the working pressure is a maximum of 60 psi.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 14-03-2014, 22:21
Coach,
There is no rule about compressor orientation but there are a few things to consider.
1. If you use the rubber isolators to mount, they are not intended to be used in tension and so have a tendency to fail over time.
2. The compressor gets hot and heat rises, putting the heat back into the compressor body.
3. It hard to see if it is running by looking into the robot.
Unread 14-03-2014, 23:39
KennyLives's Avatar
KennyLives KennyLives is offline
Grand Vizier of Pneumadynes
AKA: Kenneth Prouty
FRC #2122 (Team Tators)
KennyLives is an unknown quantity at this point
I have heard that the Viair compressors use gravity-based seals. It's possible that's why you're having those issues. I would also recommend testing your pressure switch, as they come in a number of varieties and aren't very noticeably different from each other. If all else fails, you might want to see if the old Thomas compressors will work for you.
No leaks. Ever.
Unread 15-03-2014, 00:36
AKA: Roger Moore
I just found this in the user manual
1. Select a FLAT, UPRIGHT AND SECURE location where the compressor can be mounted.
It looks like it needs to be mounted upright
http://www.viaircorp.com/90C.html
http://www.viaircorp.com/images/manu..._95_Manual.pdf
Stronghold
Student 2013-2016
Unread 15-03-2014, 05:49
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
That is very curious, I work with quite a few compressors with similar build/technology and have seen them mounted in every way possible.
The orientation should not effect the performance of the compressor.
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 15-03-2014, 08:12
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Make sure the regulator is not put in backwards.
Unread 15-03-2014, 19:57
AKA: Roger Moore
That's what I thought too. But now I am not very sure.
Stronghold
Student 2013-2016
Unread 15-03-2014, 20:02
tStano tStano is offline
AKA: Sparks
Team Role: Electrical
tStano will become famous soon enough
Also, check your dials. When we had this problem last year, it turned out we were at pressure, but our dial said we were at like 80. That happened again this preseason.
Unread 15-03-2014, 09:12
Pendulum^-1's Avatar
Pendulum^-1 Pendulum^-1 is offline
AKA: Jim Grove
FRC #1915 (Firebird Robotics)
Pendulum^-1 is just really nicePendulum^-1 is just really nicePendulum^-1 is just really nicePendulum^-1 is just really nice
We had a situation where the compressor would not get above 60 psi. Spent hours troubleshooting various items. Turned out that every component in the system was operating fine. It was the system itself that was the problem. A hose bypassed the regulator, in effect turning the whole system into a low pressure system.
I know, incredibly stupid of us to do that. And somewhat subtle to diagnose and troubleshoot.
Check to see that the high side all feeds into the proper side of the regulator, and all of the low/working side feeds from the output side of the regulator, and that no hose bypasses the regulator.
Jim Grove, Mentor
firebirds1915.blogspot.com
(2007-2017) 1915, McKinley Tech HS, Washington, DC
(2009) 2932, Mid-Pac Institute, Honolulu, HI (Rookie Season)
(2011) 2425, Hillsborough HS, Tampa, FL
(2013-2015) 4464, College Park, MD, 2013 Rookie All Star Winner and 2014 Regional Champions, Washington, DC
FIRST is not rocket science. But it is like drinking from a fire hose.
