Go to Post In the end the important thing is that the rookie members who make up the majority of our team were inspired and will try much harder next year. :) - aeniug2 [more]
Unread 16-03-2014, 11:08
Cataclysmatic Cataclysmatic is offline
AKA: Tyler Thompson
FRC #4296 (Trident Robotics)
Team Role: Driver
Cataclysmatic is on a distinguished road
MaxBotix Sonar Sensor Analog not working
Hello,
I have recently been trying to test a few things sensor wise in advance of our next regional, but I cannot seem to get the MaxBotix Sonar sensor to work, everything seems to be fine by multimeter, but I am not actually able to read a voltage in C++ using GetVoltage() or GetAverageVoltage(), I assume either one of these would probably work for my desired function.
How the sonar is wired/plugged into the analog card in slot 1:
http://imgur.com/idGN4Tr
http://imgur.com/Ajw5fmr
As for the actual code:
Declaration:
AnalogChannel *Sonar;
double voltageSonar;
Construction I have tried two different ways, neither have worked.
Sonar = new AnalogChannel(1, 8);
Sonar = new AnalogChannel(8);
Inside TeleopPeriodic I have tried:
voltageSonar = Sonar->GetVoltage();
voltageSonar = Sonar->GetAverageVoltage();//Only used one of these, but are both methods I used for testing.
SmartDashboard::PutNumber9"Voltage: ", voltageSonar);
I know that I still have to scale the voltage, but I actually need to read a voltage in order to do so... Does anyone have any ideas as to what I am doing incorrectly?
Thanks!
Unread 16-03-2014, 13:36
Re: MaxBotix Sonar Sensor Analog not working
You can't use Analog Channel 8 on Module 1, it is used for battery voltage monitoring. Choose another channel.
Unread 16-03-2014, 15:02
AKA: Tyler Thompson
Team Role: Driver
Should have probably checked at each channel, I know there are other spots throughout that do not function properly because of things like that.
Thanks for the help, it now is functioning properly.
