Thread Tools |
Rating:
Display Modes |
Hello! I've been looking through the manual for any last-minute modifications we might need to do and I came across rule R23 concerning the bumpers.
Re: Rule R23
"Articulated" means moving the bumpers relative to the frame perimeter during the match.
Relative to your frame perimeter, the bumpers must be in a static position during match play. You can however take the bumpers on or off after matches, or switch the color if you have reversibles, that is allowed. If you have questions about your specific design, please post pictures and/or descriptions. |
Re: Rule R23
Re: Rule R23
See Q198 in the FRC Q&A.
In the future, go to https://frc-qa.usfirst.org/Questions.php, click on a category (and, optionally, the filter), then click the Search button for each section of the rules. It all makes good reading. (It's a place not really obvious unless you see it mentioned.) |
Re: Rule R23
So if you have bumpers that are attached to pnumatics, that extend out and in the game. That is most likely illegal right?
Re: Rule R23
In theory, that's the idea.
#7
Re: Rule R23
Re: Rule R23
Don't worry, I believe that the rest of the rules were followed. And what do you mean by "if our hinges are okay" ? How could they not be okay?
#9
Re: Rule R23
Rule R32 about articulated bumpers is in the Robot section of the rules, not the Game section of the rules. Therefore, it is a robot requirement. It does not say that the bumpers may not be articulated during match play, it says that they may not be articulated, period. To me, that implies that ANY articulation is illegal, whether or not it's powered and whether or not it occurs or can occur during a match. My understanding from your comments is that the hinges allow easy access/installation, but you have something additional like pins or bolts that you use to secure them to the frame perimeter so they cannot "hinge" during a match. If that is the case, the hinge AND whatever pins you are using to fix the bumpers to the frame perimeter are both necessary parts of your bumper mounting solution. Without both of those, your bumpers aren't fully installed. With them installed and fixed, they can't articulate so they aren't articulated. It would be akin to someone who has a bumper mounting system that drops into slots, and then the pin through the slots. If you just drop them in and then go to inspection, they'd fail you for not being a rigid and robust mounting system, but it's never designed to compete like that because that's not the complete mounting system. |
#10
Re: Rule R23
Re: Rule R23
