PIDSubsystem works once then disables the entire RobotDrive
I can enable, drive, then use the pid to setpoint my drivetrain, drive somemore but if i reenable the pid it breaks the drivetrain.
* To change this license header, choose License Headers in Project Properties.
* To change this template file, choose Tools | Templates
* and open the template in the editor.
package us.mn.k12.fairmont.robotics.subsystems;
import edu.wpi.first.wpilibj.Encoder;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.command.PIDSubsystem;
import edu.wpi.first.wpilibj.networktables.NetworkTable;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboard;
import us.mn.k12.fairmont.robotics.RobotMap;
import us.mn.k12.fairmont.robotics.commands.CommandBase;
import us.mn.k12.fairmont.robotics.commands.DriveWithJoysticks;
* @author Teacher
public class DriveTrain extends PIDSubsystem {
// Put methods for controlling this subsystem
// here. Call these from Commands.
RobotDrive drive = new RobotDrive(RobotMap.frontLeftMotor, RobotMap.rearLeftMotor, RobotMap.frontRightMotor, RobotMap.rearRightMotor);
Encoder enc = new Encoder(RobotMap.frontRightEncA, RobotMap.frontRightEncB);
// Timer timer = new Timer();
public DriveTrain() {
super("Drivetrain", 6, 0, 0);
setAbsoluteTolerance(10);
enc.start();
public void initDefaultCommand() {
// Set the default command for a subsystem here.
setDefaultCommand(new DriveWithJoysticks());
public void driveMechanum_Cartesian(double rightJoyY, double rightJoyX, double rotation) {
drive.mecanumDrive_Cartesian((rightJoyY * -1), rotation, rightJoyX * -1, 0); // Mechanam wheel rollers should form an x when looking directaly down from the top
public void putPID() {
CommandBase.table.putNumber("p", 8.0); // change it to smartdashboard getnumber tomorrow when you arent bored of deploying
CommandBase.table.putNumber("i", 0.0); // HOLY shoot YOU FIXED THE MOMORY LIEEK
CommandBase.table.putNumber("d", 0.0);
public double updateStatus() {
SmartDashboard.putNumber("Enc", enc.getRaw());
return enc.getRaw();
public void reset() {
enc.reset();
reset();
public double returnPIDInput() {
public void setSetpoint(int setpoint) {
setSetpoint(setpoint);
public void getSetpoint(int setpoint) {
getSetpoint();
public void getPosition(int position) {
getPosition();
public void updatePID() {
RobotMap.p = CommandBase.table.getNumber("p", 8);
RobotMap.i = CommandBase.table.getNumber("i", 0);
RobotMap.d = CommandBase.table.getNumber("d", 0);
getPIDController().setPID(RobotMap.p, RobotMap.i, RobotMap.d);
public void usePIDOutput(double output) {
driveMechanum_Cartesian(output, output, 0);
package us.mn.k12.fairmont.robotics.commands;
public class DriveToDistance extends CommandBase {
boolean go;
double setpoint;
* Require the drive train and store the desired setpoint.
* @param setpoint The desired setpoint for the drive train.
public DriveToDistance(boolean go, double setpoint) {
requires(drivetrain);
this.go = go;
this.setpoint = setpoint;
// Called just before this Command runs the first time
* Set the setpoint to the stored value and enable PID on the drivetrain.
protected void initialize() {
System.out.println(this);
if (go) {
drivetrain.enable();
drivetrain.setSetpoint(setpoint);
// Called repeatedly when this Command is scheduled to run
protected void execute() {
// Make this return true when this Command no longer needs to run execute()
* @return true when it's close enough to the setpoint
protected boolean isFinished() {
return drivetrain.onTarget();
// Called once after isFinished returns true
* When this command ends, disable the drivetrain's PID
protected void end() {
System.out.println("done");
go = false;
drivetrain.disable();
// Called when another command which requires one or more of the same
// subsystems is scheduled to run
* When this command exits, disable the drivetrain's PID
protected void interrupted() {
end();
* @author Teacher
public class DriveWithJoysticks extends CommandBase {
public DriveWithJoysticks() {
// Use requires() here to declare subsystem dependencies
drivetrain.driveMechanum_Cartesian(oi.getRightJoyY(), oi.getRightJoyX(), oi.getRightJoyR());
// drivetrain.drivetest(oi.getRightJoyY(), oi.getLeftJoyY());
return false;
A description of what happens when it breaks the drivetrain would be helpful.
Re: PIDSubsystem works once then disables the entire RobotDrive
A couple of things:
First thing, in the initialize function of drive to distance, you should reset the PID. Otherwise the second time you call it the PID isn't zero'd Quote:
A description would be that it spams RobotDrive not updated enough and everything on the robot works except the drivetrain, and I deploying the suggestions of lineskier.
Thanks for the input ![]() EDIT: Code:
[cRIO] edu.wpi.first.wpilibj.networktables2.server.ServerConnectionAdapter@a entered connection state: CONNECTED_TO_CLIENT [cRIO] [cRIO] Affirmitive. I read you dave. [cRIO] [cRIO] Open the door HAL! [cRIO] DriveWithJoysticks [cRIO] DriveToDistance [cRIO] done [cRIO] DriveWithJoysticks [cRIO] DriveToDistance [cRIO] Robot Drive... Output not updated often enough. [cRIO] Robot Drive... Output not updated often enough. [cRIO] Robot Drive... Output not updated often enough. Code:
boolean go;
double setpoint;
this.go = go;
if (go) {
drivetrain.getPIDController().reset();
drivetrain.getPIDController().enable();
drivetrain.getPIDController().setSetpoint(setpoint);
return drivetrain.getPIDController().onTarget();
go = false;
drivetrain.getPIDController().disable();
end();
* @author Teacher
enc.start();
CommandBase.table.putNumber("p", 8.0); // change it to smartdashboard getnumber tomorrow when you arent borend of deploying
enc.reset();
reset();
driveMechanum_Cartesian(output,0, 0);
I have more detail after playing around with what triggers it.
https://www.google.com/search?q=recu...sm=93&ie=UTF-8
Try the "Did you mean". Now look at this line of code: Quote:
#7
Output with my comments: Code:
[cRIO] [Squawk VM] Version: 2011 FRC, Nov 5 2011, 14:34:13 [cRIO] FPGA Hardware GUID: 0x1394f6dc1feb42ec6910e5767ed1d22c [cRIO] FPGA Software GUID: 0xa14c11bde4bb64aef6a86fc52a294cd9 [cRIO] [cRIO] Affirmitive. I read you dave. [cRIO] [cRIO] edu.wpi.first.wpilibj.networktables2.server.ServerConnectionAdapter@1d entered connection state: GOT_CONNECTION_FROM_CLIENT [cRIO] edu.wpi.first.wpilibj.networktables2.server.ServerConnectionAdapter@1d entered connection state: CONNECTED_TO_CLIENT [cRIO] Open the door HAL! [cRIO] Robot Drive... Output not updated often enough. // right when i enable, what is that all about? [cRIO] DriveWithJoysticks // i move around the floor and read output from the enc on my smartboard [cRIO] DriveToDistance //press button 11 and it goes to setpoint 100 [cRIO] done [cRIO] DriveWithJoysticks //drive around some more and then disable, if i dont disable and reenable same thing happens so it doesnt matter [cRIO] Robot Drive... Output not updated often enough. [cRIO] Open the door HAL! //enable and press button 11 [cRIO] DriveToDistance [cRIO] Robot Drive... Output not updated often enough. [cRIO] Robot Drive... Output not updated often enough. [cRIO] Robot Drive... Output not updated often enough. [cRIO] Robot Drive... Output not updated often enough. [cRIO] Robot Drive... Output not updated often enough. [cRIO] Robot Drive... Output not updated often enough. [cRIO] Robot Drive... Output not updated often enough. [cRIO] Robot Drive... Output not updated often enough. [cRIO] Robot Drive... Output not updated often enough. [cRIO] Robot Drive... Output not updated often enough. [cRIO] Robot Drive... Output not updated often enough. [cRIO] Robot Drive... Output not updated often enough. [cRIO] Robot Drive... Output not updated often enough. [cRIO] Robot Drive... Output not updated often enough. [cRIO] Robot Drive... Output not updated often enough. [cRIO] Robot Drive... Output not updated often enough. [cRIO] Robot Drive... Output not updated often enough. [cRIO] Robot Drive... Output not updated often enough. [cRIO] Robot Drive... Output not updated often enough. [cRIO] Robot Drive... Output not updated often enough. [cRIO] Robot Drive... Output not updated often enough. [cRIO] Robot Drive... Output not updated often enough. // here stuff works but not any drivetrain stuff //////// Here i turn off(physical switch) and turn back on the robot and now it works again! [cRIO] Open the door HAL! [cRIO] DriveWithJoysticks [cRIO] DriveToDistance [cRIO] done [cRIO] DriveWithJoysticks Code:
* @author Teacher
enc.start();
// public boolean autoDrive(int dist, double speed) {
// System.out.println("going fishes");
// enc.reset();
// while (enc.get() <= dist - 100) {
//// tal.set(speed*(.1*(dist-enc.get())));
// if (enc.get() <= dist - 100) {
// driveMechanum_Cartesian(speed, speed, 0);
// } else if (enc.get() >= dist + 100) {
// driveMechanum_Cartesian(-speed, -speed, 0);
// return true;
// // credit to team 1160's github for pieces of this
// public void autoTimeDrive(double time, boolean run) {
// timer.start();
// timer.reset();
// while (run) {
// driveMechanum_Cartesian(.3, .3, 0);
// System.out.println(timer.get());
// if (timer.get() >= time) {
// driveMechanum_Cartesian(0, 0, 0);
// run = false;
public void resetthing() {
enc.reset();
driveMechanum_Cartesian(output/4,0, 0);
boolean go;
double setpoint;
this.go = go;
if (go) {
go = false;
end();
#8
It looks to me like your DriveToDistance command will only work one time the way you have it coded. The "go" flag was being set to "false" in the original end() method in the original implementation. Once the flag is set to false, then your drive train PID was never enabled on any subsequent invocation (until you power cycle).
Can you try refactoring it without the "go" flag to something like: Code:
double setpoint;
public DriveToDistance(double setpoint) {
end();
#9
Both of these suggestions look solid to me. |
#10
Thank you both, I'm testing this now. I was looking at the documentation on how commands are called and i wasn't sure if the go thing was necessary.
EDIT: IT WORK ZOMGLOLOLOL IM SO HAPPY I LOVE YOU ALL I CAN SETPOINT AS MUCH AS I WANT AND NOMORE ROBOTDRIVE TIMING OUT!!>!>!>!>!>>!! Thanks lineskier and pblankenbaker! It ended up being the go bool and I'm looking into the timeout thing. I'm so happy because we go to competition today, and i can make code for the main robot now! Last edited by fireXtract : 26-03-2014 at 10:03. |
