Thread Tools |
Rating:
Display Modes |
Week4 Twitter data analyses
This thread is for discussion of Week4 Twitter data analyses posted here: http://www.chiefdelphi.com/media/papers/2985 I will be adding additional analyses as time permits. Special requests will be considered also. |
Re: Week4 Twitter data analyses
Let me start by saying thanks for all that you do for this community...I have grown tremendously over the last several years reading your posts.
What is uCCWM? CCWM without foul points? |
I really like EPA. Certainly more useful for cross event comparisons than raw OPR/CCWM. Wish we could tie in average event score or something of the like to EPA. Being able to view OPR separate from fouls and EPA certainly helps remove outliers from the data.
Thanks for the data as usual. ![]() Last edited by Navid Shafa : 23-03-2014 at 19:48. |
Look for Average Alliance Scores at each Event near the bottom of the list of attachments: http://www.chiefdelphi.com/media/papers/2985 Not sure what the best way would be to integrate these with EPA. |
I'd like to get some feedback on which of the attachments you'd like to see again for Week5. I need to pare it back a bit. http://www.chiefdelphi.com/media/papers/2985 |
Posting here because it's a very similar subject.. On request of some twitter people, I used the @frcfms data to determine the % of matches determined by fouls (any change in result, including from or to ties) over the past three years, broken down into years and categories such as quals, semifinals, or 3rd match of an elimination series. Those statistics are available here: http://goo.gl/mKuTXS.
#7
EDIT: It doesn't seem like assist points are part of the FMS feed. Is there another resource out there I could mine for analysis? Last edited by brennonbrimhall : 31-03-2014 at 16:36. |
#10
The only true way to know assist points by match is to recalculate them after every match based on USFIRST's ranking page. Otherwise, you need a new data source from FIRST, i believe. The scoring/index.lasso page on USFIRST (You can find it's link and related links via a google search) looks promising, but I haven't found any match information from there.
#11
Twitter data1 has final score, foul points awarded, autonomous, and "TeleOp"2 for each match Match Results has final score for each match Team Standings has Assist, autonomous, Truss&Catch, and "TeleOp"3 for each Team (total of all alliance scores for alliances on which the team played). 1The usual Twitter data caveats apply. 2Twitter "TeleOp" is equal to Assist + T&C + Goals 3 Team Standings "TeleOp" is equal to Goals + Fouls |
#12
My null hypothesis was that each match had the same proportion of matches decided by fouls. With the percentage of matches that are decided by fouls being 23.34%, my x^2 value ended up being 46.4. I came up with a p-value of 5.06945E-07. So clearly, weeks and match type produce different numbers of matches decided by fouls. Code:
MDBF Played Expected Difference X^2 Std. Resid. 1E: 29 159 37.11062625 -8.110626253 1.772598979 -1.331389868 1Q: 228 783 182.7523293 45.24767072 11.20287612 3.347069781 2E: 61 205 47.84703385 13.15296615 3.615699965 1.901499399 2Q: 312 1039 242.5027716 69.49722845 19.91674046 4.462817547 3E: 48 264 61.61764359 -13.61764359 3.009531137 -1.734800028 3Q: 293 1237 288.7160042 4.283995754 0.06356634 0.25212366 4E: 41 245 57.18304045 -16.18304045 4.579868371 -2.140062702 4Q: 253 1184 276.3457955 -23.34579549 1.972261479 -1.404372272 5E: 64 283 66.05224673 -2.052246727 0.063763412 -0.252514182 5Q: 340 1493 348.4664465 -8.466446515 0.205703353 -0.453545316 |
#14
Yes. It's CCWM without foul points (the "u" stands for Unpenalized). Sorry about that. I forgot to explain it.
uCCWM = ( final - foul ) - ( op_final - op_foul ) "regular" CCWM = ( final - op_final ) Code:
EPA = ( final - foul ) - uAvg DPR = op_final uDPR = ( op_final - op_foul ) Last edited by Ether : 24-03-2014 at 10:43. |
