Team 955's Scouting Program!
https://github.com/FRC-Team-955/Aeri...tScouting-1.2/ Run it from Github: https://rawgithub.com/FRC-Team-955/A...ode/index.html |
Re: Team 955's Scouting Program!
You need two gamepads to run the program, the first one connected adjusts red team values, the second, blue. You can upload a match list text file, and it will automatically fill in the team numbers with each match number; an example file is attached.
After each match, hit the save button and it will generate a .csv file. Once you've got a collection of matches that you want to analyze, hit the "Create Master File" button, select the match files, and it will generate a complete file with all the teams and team scores. Team values are averages and totals. Key maps: Right/Left Bumpers: Toggle between teams Start: Toggle Teleop Select: Toggle Autonomous Autonomous: A: Low hot goal B: Low goal X: High goal Y: High hot goal D-Pad: Starting Zone Teleop: A: Low goal B: Truss score X: Pass Y: High goal D-Pad: Zone Preference Tags: 1: Defensive 2: Successful defense 3: Offensive 4: Successful offense 5: Broken 6: Can catch from player 7: Loose grip 8: Two Ball Autonomous 9: Good with (your team) Last edited by Monochromicon : 03-04-2014 at 18:13. Reason: Tag fix |
