Thread Tools |
Rating:
Display Modes |
Bad Robots
So I apologize if this comes off sounding too judgmental or arrogant, but I have a question I've been wondering about for a while now.
My pre-rookie team and I went to a regional this weekend to go see the game played, and check out some of the robots. We were excited for some really innovative, great designs and fun gameplay. But when we got there, we found the reality to be a little different. In the qualifying matches we saw, most of the teams could not even pick up the ball well, let alone shoot, and the brief moments of good gameplay were provided by one good robot essentially playing the game by itself. I guess my question is multifaceted, first - is this common in FIRST, in Aerial Assist, or was it just this regional in particular. Also, what is the build season like for teams who end up with a robot that just doesn't play the game well? Is it a lack of resources, a lack of time, or poor strategy? And most importantly, what can my rookie team do, before build season and during, to build a robot we're proud of and can play the game well? Again, I'm truly sorry if this came off as offensive, but it was an issue that bugged many of my teammates as well, and we tried to phrase this in the most diplomatic way possible. |
Re: Bad Robots
This is probably just the particular regional you went to, I've seen tons of action, but I'm out here in California. As for build season, usually a poor robot is the result of a design that was either too complex and had to be scrapped at the last minute or a design that has been changed too much. Lack of resources is also grounds for a less competitive robot, but I've seem some pretty great robots that were made out of garages. To prepare to build your own bot, I suggest you talk about what strategy you're trying to implement, what you want your robot to do, and then look at some existing designs from others teams for inspiration on how you could build your robot.
Re: Bad Robots
There are always teams that struggle. Even for "simple games," building a robot is a difficult task. Some regionals are worse than others. Some years are worse than others. Some teams bite off too much to chew. Some teams don't have enough guidance. Some teams are impacted by scenarios outside of their control (snow, for instance). There's no single "magic bullet" to solve this problem, or else it would have been solved a long time ago.
Re: Bad Robots
And Canada (of course). We still have snow up here.
Re: Bad Robots
The eliminations would have been far more inspiring. Unfortunately not every team has the resources (human, fiscal, or facilities) available to produce a top caliber robot. The reality of the situation is that building robots is very hard to do, and for many teams a success is just having something out on the field that functions.
Re: Bad Robots
I agree with MrTechCenter
Biggest advice I can give is to not try and do too much in your first year. Too many teams (veterans included) try and do too many things and end up not being able to do any one thing well. Focus on getting a strong working drivetrain If you go with a basic tank drive (also my recommendation), use at least 4 cims). Many teams are looked over in alliance selection if they have a poor drivetrain even if they have functioning other parts of their robot. After you have a working drivetrain, focus on getting one mechanism working for the current years game. Like this year, an arm to posses the ball and let go will make you extremely valuable to teams at regionals. Finally, seek out veteran teams who seem to know what they are doing if you need help (you are already ahead in that aspect). Good Luck! |
#7
Re: Bad Robots
Robots that can't play the game more than just defense? All too common. Robots with nonfunctional scoring mechanisms? All too common. Robots that are too complex? See last two statements... The three most important parts of an FRC robot are drivetrain, drivetrain, and drivetrain. (And bumpers, which protect the drivetrain.) Keep it simple and tough, then get one thing working in terms of handling the game piece (preferably acquisition) then get one other thing working on that (preferably getting it out of your robot!). |
#8
Re: Bad Robots
There's a line between 'not doing too much' and betraying the program by not challenging yourself. Toeing the aforementioned line is what teams of all levels struggle with. - Sunny G. |
#9
Re: Bad Robots
Understanding the logic behind the Minimum Competitive Concept in conjunction with getting early practice building drivetrains in the off season (and driving the heck out of them) will put you off to a great start. Depending on your region, there are probably veteran teams in your area with old kit chassis that either went unused or are obsolete. Be sure to contact veteran teams in your area to see if you can have one (special shout out to 360 for doing just that). For a control system, even something as simple as a 4 channel RC airplane transmitter/reciever combo and some spare motor controllers (jaguars, talons, victors, etc.) is sufficient to replace a $500 cRIO/digital sidecar combo if your only goal is to drive around (though you'll still have to get a battery and an electrical distribution setup going). Our first "robot" did nothing other than trundle around at a very slow clip, but if you set up a basic obstacle course, you instantly have a Tank Drive 101 class for new drivers.
We used essentially this package right here. It won't get you programing practice, but it's a very low-cost start. |
#10
Re: Bad Robots
To answer OP's questions, it really does vary based on what regional you attend. There are some locations where most teams have great resources and can make great robots. Other locations may not have as many resources, possibly caused by a lack of students, mentorship, or sponsorship. |
#11
Re: Bad Robots
I DEFINITELY agree with hedgehog on the failure aspect. One of the things he didn't mention was the the main feature of our robot, namely a large shield, was actually making the best out of a bad situation. we had meant to make the robot climb the pyramid (the endgame last year) and get 30 points. after we failed at doing that, we decided to build a shield, making use of the existing mechanisms. It worked for us. (it also made a stylish way to show off our tshirt)
also, a corollary to failing, everything will break. We literally had no system on the robot NOT break by the end of last year, the omniwheels even fell apart, and the kit wheels are BALD (to the point where i'm surprised the DMV didn't say anything )Good luck next year, I hope you do well! You're already thinking like a veteran. just be prepared to work some late nights, and NEVER lose hope in yourself, your robot, and most importantly, your team! |
#12
Re: Bad Robots
Congrats you have experienced the great divide.
#13
Re: Bad Robots
It's fairly common in FIRST, and varies regional to regional. The best advice I can give is to a team that wants to achieve the game goals is to look at Simbotics's website (simbotics.org) and look over their resources section. Their section on strategic design is invaluable to a startup team.
Also, be sure to look back at some old games and have a few people well versed on what types of mechanisms work well for manipulating certain types of game pieces. Even if the game piece isn't very similar to a past one, it still gives you some ideas to try to adapt to the new game piece. |
#14
Re: Bad Robots
I don't know who your coach is, but he/she definitely placed you on the best path for your team's rookie season by attending a regional before you begin.
As a team that has competed in the last two seasons - here is the advice I would slip you to help the process. (It definitely helped us) 1. Get a hold of your state's organizers and get them on board immediately with your team. We did this (here in MN we have a great FRC community) and rally them to your cause. 2. Contact your local Chamber of Commerce/Manufacturers association and ask if your team could present at their upcoming meetings or conferences. Contact your local paper and find a field reporter that would be willing to cover your endeavor. Invite your school's administration to the meeting(s). Polish the presentation, bring in state reps from FRC, and knock their socks off with stats and figures. And then ask them to help with mentoring, organization, and sponsorship. 3. Get your ducks in a row early. Starting as soon as possible get the funding in place. Apply for FRC first year sponsorships, organize a few fundraisers to get the cash in-flow moving. 4. Find a reseller/scrap yard/wholesaler that deals in all things industrial - it is a cheap way to gain structural material (like 8020 components). 5. Build a skateboard/drive deck/platform as soon as you can afford to and start planning your drive train asap. You most likely won't have access to 2015's new RoboRio - so having the CAD plans or a workable deck ready will be paramount. Just keep the FRC notes on pre-season build on hand. 6. Get the superfluous items off your list early (member sign up, logo, website, shirts, parent organization, etc.). Having this done will free up a lot of time during the build season. 7. Get in touch with well-established local teams (again, thank you 1816 and 3023) and ask for help. 8. Attend a pre-regional event. 9. Set the bar high and expect that your team will have a lot of failures during the build season - but strive for nothing short of the best. 10. If you need more help, please contact FRC 4607 if you need any other pointers... we are more than willing to help your team where we can - so many have done the same for us! GOOD LUCK! |
#15
Re: Bad Robots
I will add one thing to "Chief Hedgehog's" great list: Set yourself the goal to complete your build in 30 days rather than 45...
(1) If you succeed you will have a solid two weeks to give your drivers practice time - you can never have too much practice time...or... (2) You will have time to build a second robot for competition and use the first one to practice. (3) If you fall a bit short, you still have time to finish (4) You get the opportunity to see what parts of the robot don't work quite the way you planned, what items come out of adjustment easily, and what things require constant maintenance. (5) This gives you the opportunity to show your robot off to your sponsors and community to get them excited and increases your financial viability for the following year. As to the observation about the number of "bad robots" I tend to agree, and (without invoking a great deal of angry replies) I believe most of the "reasons" that are cited are just excuses. I inspected during week one in Palmetto, and was astounded by the number of teams who came with a robot that was far from finished, or marginally useful at best. The Andymark AM14U drivetrain was an awesome resource this year, which meant that any team could have a great driving base before they left kickoff (do all kickoff events have a robot quick-build session?). Even if that is all a team managed, they would have been useful to an alliance this year. Especially if they spent the rest of the build season practicing and devising strategies. |
