Problem with AM 9015 motor
Hi guys
I have an AM 9015 motor that I am running from a 12v power supply when I turn it on, it spikes and draws around 1.5 amps and then settles to 1.2 amps like the free current specs say usually when I run it, it spikes to 1.5A and then runs for a .5-3 seconds and then stops, I can see the fan in the back twitching but it won't turn (happens in both directions) other times it won't start at all and turning the motor a few degrees causes it to repeat the symptoms above (run for a bit then stop and twitch) all of this happens without a gearbox attached but when I attach a versaplanetary 10:1 the issue is the same my initial thoughts are it is not getting enough current or the wire is too small to give it enough current (20 AWG) but according to the power supply it is not trying to draw much more current so that is confusing me any ideas on why this is happening? thanks |
Re: Problem with AM 9015 motor
In some motors like those and the Fisher Price motors, if the mounting screws are too deep they will jam into the internal coils and mechanically halt the motor. Otherwise, it is possible that some of the little fan blades at the back have broken off and are in the way. I cannot think of any reason a healthy motor would fail other than these reasons (the motor will run just fine with a few fan teeth missing, so long as they are cleared)
Have you tried a second/replacement motor? It sounds to me like there might be an intermittent short, similar to the RS-775 issues a number of years ago.
what is the maximum current rating on the power supply?
