| Nothing in the KOP can prepare me for you. |
Thread Tools |
Rating:
Display Modes |
Butterfly/ octocanum drives
So a butterfly/ octocanum drive is where you switch between mecanum and traction wheels, right?
I was wondering what the typical weight and complexity of these systems was. This would be weight per module or, preferably, weight of bellypan + drive base + modules. I have only found one weight listing for an octocanum module, and I think many teams keep the mass under 11lbs. How long does this take to design? Does this need a particular CNC special part or can it be fabricated with a waterjet/ sheet metal shop? Any information on these drives would be useful, as I'm looking into different drives for a summer project. Last edited by asid61 : 29-04-2014 at 01:20. |
Re: Butterfly drives
I would encourage you to sit down with your team and figure out a list of objectives you would like your summer project to fulfill. Once you've done this I would encourage you to use the chiefdelphi search function to read up on butterfly drives from older threads. Once you understand your design objectives, have an idea of where a butterfly type drive falls on that, and seen a number of designs other teams have already made you can properly assess if you should try to design and build one or if your time would be better spent working on something else. When done properly off season projects can be an extremely valuable resource both in terms of populating your team's design shelf and teaching students. The most important thing is to have a full understanding of why you are building what you are building and how you are trying to improve upon what you have done in the past, have seen others do in competition, or online. Cheers, Bryan Last edited by BJC : 29-04-2014 at 01:41. |
I've been cadding only swerve drives and shifting gearboxes up to this point, but I was wondering what I should aim for in terms of weight and size if I CAD a butterfly later. I want to stick with swerve personally, but the problem is that the programming is very difficult. With a butterfly drive, there is already a lot of programming released, not to mention the programming overall is easier. |
Re: Butterfly/ octocanum drives
The main difference between the two are choosing what wheel is opposite of the traction wheel on the pod. While I have not built one, the drives should be slightly heavier than a conventional drive. Majority of these setups use a single gear reduction to the first wheel and then another reduction via chain or belt to the second wheel. This makes up for the weight "missing" from gearboxes. There are some good examples out there on how they have been constructed in the past. 148 made this type of setup popular in their 2010 release video and their CAD files can be seen on FRC designs and you can see another iteration in their 2011 robot. Another great example is 3847's robot from this year. It was documented fairly well in their build blog. Both of these teams are more than willing to help answer further questions, but these should give you a good starting point. There are plenty of other robots that use these drive types that I didn't mention, these were two I could get my hands on quickly. |
http://www.chiefdelphi.com/forums/sh...9&postcount=15 |
#7
I think terminology, albeit important, can sometimes limit creativity. |
#8
Thanks for all the replies. I especially enjoyed the Grasshopper drive (I saw that a couple weeks ago) because it seemed very lightweight @ 30lbs. Also, it didn't look like it would take too much effort for even an inexperienced team due to the fact that the amount of lift on the wheels could vary quite a bit.
So it looks like these modules are a little on the heavy side at around 8-12 lbs, maybe 6 or 7 optimized. It looks like these could be pretty useful to us next year in leiu of a heavy swerve. Thank you so much for all the input! |
#9
Our octocanum modules are 5.75 lbs. each. The pneumatic cylinders driving each pod were mounted to the frame and I don't have the weight of each of those handy. We used four, but you could as easily use 1, 2 or 4 as your frame allowed.
Our first octocanum implementation in 2011, itself the first used in FRC, was made entirely in-house and with no advanced machining techniques. It was designed and built in just a few weeks and while heavy, it was very reliable and effective. Our 2014 implementation is made with sheet metal and that helped us to realize a lot of weight savings. We relied on our experience from 2011 to design and code the drive quickly. |
#10
We have a sheet metal guy, but CNC is up in the air right now (our local college can only machine on weekends and they like the manuals). |
#11
I've been looking at octocanum drive trains as well and come up with several designs so far. I found this thread of 2583's design very useful, and there's information about calculating whether or not you get enough force out of your piston to lift the robot. Also, it's definitely possible to make a working design without CNC or anything heavy duty, but you'll probably want to use belts or chains if that's the case, so you can tension out any discrepancies in hole spacing. We've actually already started on a very crude prototype with chains, but we plan on upgrading to gears in the final design.
As for how long it takes to design, I'd say not very long at all, so long as you have a relatively clear picture of how the finished product will look like. And given the many existing designs you can access, that shouldn't be too hard. |
#12
If you're talking about octocanum without CNC, I believe 525 ran a handmade octocanum setup for a few years. Might be worth checking out their CAD files (among other reasons to check out their files-- they have the most detailed modeling I've ever seen from a team).
#13
We built an octanum system without regular access to CNC equipment. I do not recommend doing that unless you have an experienced machinist guiding the manufacturing effort and making sure the parts are being made accurately and consistently.
There are similarities and differences between our modules and the modules that 148 used. Both our modules used one of the axles in each module as the "pivot axle" for the module to move up and down. In our modules, the pivot axle was a live axle making it necessary to install bearings in the chassis to hold the axle. We also had bearings on the side plates of the module. In 148's module, the pivot axle was a dead axle so the wheel on that axle had bearings in it. Their module side plates had bearing just like ours. Their pivot axle was screwed into the chassis with a 1/4-20 bolt at each end. I think our modules had the same number of major parts as 148's modules so the complexity was similar. The big difference was manufacturability and serviceability. Our modules could only be partially assembled before installation. We had to insert the pivot axle, it's bearings, the wheel and all the spacers while it was in the chassis. It took a lot of time and effort to make any changes to the module. 148's could be fully assembled on the workbench and installed into the chassis by screwing in the two 1/4-20 bolts. |
#14
If you design an octocanum or butterfly, be ready to spend at least two or three months to go from concept to working prototype. If you use bent sheet metal for your modules you need a water jet, if you use 1/4" aluminum plates, you need a good CNC. Do know that they can be much heavier than other drivetrains depending on their features, so they aren't suitable for some games.
