Go to Post Now the big question is, does Dave think this is pimp? - Mike Schroeder [more]
Unread 08-05-2014, 18:12
Ladiesman217 Ladiesman217 is offline
FRC #3965
Ladiesman217 is an unknown quantity at this point
Alternate robot controllers?
Hey, We are trying to build a t-shirt shooting robot for our school, but buying a C-rio is out of the schools budget. Any cheaper alternatives that you guys would recommend?
Unread 08-05-2014, 18:41
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Alternate robot controllers?
Go ahead and use your current cRio for it - you'll be getting a whole new control system with the RoboRio in the Kit of Parts next year!
2016: Lake Superior WFFA
Unread 08-05-2014, 22:19
FRC #3965
We would like to keep the 2014 robot operational, and a new crio isnt in our budget.
Unread 08-05-2014, 22:34
Domenic Rodriguez's Avatar
Domenic Rodriguez Domenic Rodriguez is offline
FRC #0316 (LuNaTeCs)
Domenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura about
The RobotOpen control system from Team 221 Robotic Systems was designed as an alternative FRC robot controller. The system is Arduino-based, and is available as either a set of Arduino shields or a standalone unit. I don't have any experience using it, but when I looked into it a while ago it seemed interesting.
LuNaTeCs - Learning Under Nurturing Adults Teaching Engineering Concepts and Skills - Small and Mighty!
FRC 316 LuNaTeCs - Student (2011-2014), Lead Programmer (2011-2014), Team Captain (2013-2014), Operator (2013), Drive Coach (2014), Mentor (2015-????)
'11 Philly Regional Finalists, '13 Chestnut Hill Finalists, '13 Lenape Champions, '13 Archimedes Division, '14 Chestnut Hill Champions, '14 Lenape Champions
FTC 7071 EngiNerds - Founding Advisor (2013-2014) | FRC 5420 Velocity - Founding Advisor (2015)
Grove City College Class of '18, Electrical/Computer Engineering (B.S.E.E)
Unread 08-05-2014, 22:58
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
What are you trying to do with the T-shirt shooter? If you provide some specs we may be able to offer better suggestions.
If all you need is basic control then an RC setup may be all you need. Something like the AM Cheap & Dirty control system.
The Sasquatch Robot Controller or RobotOpen from Team221 will give you more control.
A lot of teams use a VEX cortex to replace their cRIO on old robots.
There are also some much cheaper custom options if you only need a few controls.
Unread 09-05-2014, 01:06
FRC #3965
Basically, we need to drive, move the launcher up and down, activate a compressor, and activate the solenoid to launch the shirt.
Unread 28-08-2014, 16:38
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
gixxy is on a distinguished road
What 3946 did was use an Arduino and two XBees to make a remote control T-shirt launcher.
All the code for the Arduino (and I believe the Firmware for the XBees) is avalible on our github: https://github.com/frc3946/MobileAirCannon
What we did was have the XBee standalone in the controller, using its dedicated IO lines as inputs. Then we had the XBee on the Arduino sending that data from the Controller to the Arduino via Serial. Then I made some breakout boards for PWM (S + -) and Relay (A B -) ports.
Here is the hardware we used:
Arduino Leonardo (an Uno or Mega would work just as well): https://www.sparkfun.com/products/11286
2x XBee Pro S1 https://www.sparkfun.com/products/8742
Arduino XBee Shield: https://www.sparkfun.com/products/12847
XBee Explorer USB (For Programming XBees): https://www.sparkfun.com/products/11812
XBee Explorer Regulated (For use in Controller up to 12volts): https://www.sparkfun.com/products/11373
The rest are just buttons, joysticks, battery holders, and switches to make the controller, and some perfboard and headers for the additional breakout headers.
Programmer - A creature known for converting Caffeine into Code.
Studying Computer Science @ Louisiana Tech University
Associate Consultant @ Fenway Group
2012-13: 3946 - Head of Programming, Electrical and Web
2014 - 3468 - Programming Mentor
2015 - Present - Lurker
Unread 28-08-2014, 17:12
parkedraccoon's Avatar
parkedraccoon parkedraccoon is offline
FRC #0766
Team Role: Electrical
parkedraccoon is on a distinguished road
I'm not sure how your system will work, but if you're using Spike relays, the RobotOpen cannot drive the Relay ports on the sidecar, and driving them directly off the Arduino is iffy in terms of currrent draw (and a pain to wire). It worked great for us on a motors-only robot, but it didn't work on a robot with solenoids and relays.
"Why is it stupid?"
2006-2008 Little brother of Team 766 member
2008 FLL
2009-2014 FRC 766
2014-> ??? (hopefully some sort of mentor!)
Unread 08-05-2014, 23:16
Engineering Coach
Originally Posted by Joe Ross View Post
As Jon stated, you will not be using a cRIO on your 2015 robot.
I think they understand that. They just don't want to take their cRIO off their 2014 robot, so they can still use it for demos and things along with their new T-shirt shooting robot.
