Go to Post Of course, the banana might mean nothing. It could just mean that Dave needs more potassium in his diet. :) - KathieK [more]
Unread 13-05-2014, 21:27
tanguma26 tanguma26 is offline
FRC #3999
tanguma26 is an unknown quantity at this point
Team 221 Arduino setup and problems
Hello my name is Miguel, I purchase your arduino and have been trying to connect through the side card, we have made different programs and upload it to the arduino, when we enable it the LED is red, I have tried to use the example code that comes in the library and also nothing happens. We are using the router that comes in the kit and DriveStation from your website the chrome app and also the robotopen control that I download it. When we enable the drive station there are any changes to the arduino. We are using the following IP address 192.168.1.22 and also put it as static IP. The set up of the router we used the FRC bridge configuration. Is there certain IP address that I have to use or is there something that I am doing wrong.
We are powering the arduino through the 5V from the sidecard
Thank you very much for your help.
-Miguel.
Unread 13-05-2014, 22:28
AustinH's Avatar
AustinH AustinH is offline
FRC #4918 (The Roboctopi)
AustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to behold
Re: Team 221 Arduino setup and problems
If I remember correctly, our arduino runs natively at 10.0.0.22. Try running everything off of the 10.0.0.XX range
3826: 2013 Seattle Regional Industrial Design Award & Semi-Finalists
4918: 2014 PNW Glacier Peak District Event Rookie Inspiration Award & Quarter-Finalists, 2014 PNW Mount Vernon District Event Highest Rookie Seed Award, Rookie All Star & Semi-Finalists, 2015 PNW West Valley District Event Engineering Excellence Award & Semi-Finalists, 2015 PNW Mount Vernon District Event Semi-Finalists
Visit us on the web at www.team4918.org
Unread 14-05-2014, 09:15
akmess01's Avatar
akmess01 akmess01 is offline
FRC #3824 (RoHAWKtics)
akmess01 is an unknown quantity at this point
I don't have much experience with connecting the arduino to a FIRST setup, but you don't want to power the arduino off just 5v. If you do then the 5v that it is outputting will be lower and the board may be unstable. Their site recommends 7-12v. This is the case for many of their boards.
http://arduino.cc/en/Main/arduinoBoardUno
Alumni/Mentor:
2016- Carson Division Quarterfinalists, Smoky Mountain Regional Winners, #3 Seed; Palmetto Regoinal Semifinalist, #7 Seed
2015- Tesla Division Finalists; Smoky Mountain Regional Winners, #1 Seed; Palmetto Regional Winners, #1 Seed
2014- Newton Division; Smoky Mountain Quarterfinalists; Palmetto Regional Winners, #1 Seed
2013- Curie Division Quarterfinalists, #10 Seed; Smoky Mountain Regional Winners, #1 Seed; Palmetto Regional Finalists
Student:
2012-Peachtree Semifinalists; Smoky Mountain Semifinalists
2011-Galileo Division; Smoky Mountain Quarterfinalists, Smoky Mountain Rookie All-star
Unread 14-05-2014, 19:56
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
The OP reached out to us via email...
To reiterate, the default IP of the RobotOpen shield is 10.0.0.22.
This should solve their problem.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 15-05-2014, 04:47
chmconkling's Avatar
chmconkling chmconkling is offline
Jack of all groups. Master at most.
AKA: chris
FRC #2363 (Triple Helix)
chmconkling is an unknown quantity at this point
How do you set up the router then? Should you try and set the router up like the OpenShield (same IP)?
Unread 15-05-2014, 07:30
AKA: Anthony Lapp
You can set the router up anyway you want... I usually do a factory reset and leave it to the default setting.
You'll connect to it's wifi network, once your computer is talking to the router, then the IP connections between the laptop and shield matter.
My non-technical answer is, don't mess with the router.
Anthony Lapp
RobotOpen
