Go to Post ...if two good things are good by themselves let's do them both together to make a better thing. So who's up for an apple pie burrito? - Katy [more]
Go Back   Chief Delphi > Technical > CAD
Unread 29-06-2014, 12:57
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
Utilizing pre-made gears in a gearbox
I'm starting to design a gearbox in Inventor, and I guess I've run into a problem. Instead of using the design accelerator to make the gears, I would prefer to use gears that already exist that would be difficult to create on my own (such as dog gears or spoked gears). Is it possible to take pre-existing gear models and constrain them together like the ones output by the design accelerator (i.e with movement constraints)? If that's not possible, how would I go about properly distancing gears from one another to at least make it appear right?
Unread 29-06-2014, 14:24
avanboekel's Avatar
avanboekel avanboekel is offline
AKA: Adam Van Boekel
FRC #5934 (Gear it Forward, Crowbotics)
avanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant future
There are gear models available on Vex pro's website. They have a wide variety of gears to choose from.
There are motions constraint available for use in inventor. I don't remember exactly how to use it, but I think its in the same constraint window that you would use for a mate or flush constraint.
You can use a gear distance calculator to get the distance between gears right. They are all over the place online.
Hope this helps, let me know if you have any other questions!
2338 Gear It Forward | Student 2010-2013 | Mentor 2014-Present | oswegofirst.org
2013 Wisconsin Regional Winner (1732, 111, 2338)
2013 Midwest Regional Dean's List Finalist
2015 Midwest Regional Chairman's Award Winner
2015 Archimedes Subdivision Winner (1023, 2338, 3996, 1089)
2016 Midwest Regional Chairman's Award Winner
4096 CTRL-Z | Mentor 2014 | team4096.org
5934 Crowbotics | Mentor 2016-Present | crowbotics.org
Unread 29-06-2014, 14:55
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: Utilizing pre-made gears in a gearbox
For finding the distance between the centers of two meshing gears (in inches), you can use the following formula:
(T1 + T2) / (2*Dp) + C
Where:
  • T1 is the number of teeth on the first gear
  • T2 is the number of teeth on the second gear
  • Dp would be the diametrical pitch of the gear (Most of the AndyMark and Vexpro gears have a Dp of 20, which means that the diameter of a gear with 20 teeth is 1". Some have a Dp of 32. You can buy all kinds of neat sizes from other manufacturers)
  • C is an additional offset to make up for manufacturing tolerances. If everything could be made perfectly, then C would be 0. In real life, the hole isn't exactly in the center of the gear, the two bearing shafts aren't the exact right distance apart, etc. Most AndyMark products use a value of 0.002" or 0.003" for this offset. You can download some gearbox models and measure the distance from one bearing to the next to see this.
Unread 29-06-2014, 23:15
ekapalka's Avatar
FRC #3216
Thank you both so much!
Thank you very much :) I figured it out. Its the motion tab in the constraint window. Select roataion for the type, forward for the solution, and T1/T2 for the ratio. I just had to make sure the teeth weren't occupying the same space before I did that.
Originally Posted by s_forbes View Post
For finding the distance between the centers of two meshing gears (in inches), you can use the following formula [...]
This works perfectly. Thanks!
