Thread Tools |
Rating:
Display Modes |
pic: 4587-Sheet Metal Chassis
Re: pic: 4587-Sheet Metal Chassis
Very cool Cooper, a lot of things I plan to look into in the fall are in this.
One thing that I am definitely going to look at adding is a belt or chain connecting the modules on each side. 148 has them this year. I think it's a huge improvement for when two of the wheel modules come off the ground. I am also going to try to remove the plates that mount the motors inside of the wheel wells. They caused us problems since they aren't really piloted with gear they are driving. We have had some gear wear issues because of it. What gearing is this designed for right now? We are definitely looking at going faster next year with the amount of motors we can put on the drive. We did 6:1 and 14:! this year and we could have probably done closer 5:1 and been fine. Also I like the third CIM mount, 12 motor drive is the future for sure. (before anyone doesn't get this, that was a joke) Last edited by AllenGregoryIV : 03-07-2014 at 00:04. |
You are going to remove the interior gearbox plates? Are you going to try to float the motors with the wheels like 1477 did? It is designed for a 5:1 for 4" Omni Wheels, and 14.4 for the 3.25" traction wheel. Should be good enough for this type of setup. I think the speed will be just right for the type of driving I like to do. Oh, and those strategically placed Swiss cheese holes may never be used ![]() Last edited by Cash4587 : 03-07-2014 at 00:26. Reason: Clarity, Grammar |
We definitely won't float the motors. I'm not sure exactly what the plan is yet but the we need a better way to force the plate to be aligned properly if we would do it again. I have also thought about moving the motor mounts to between the two wheels but haven't actually CADed anything yet.
If this is your first time with sheet metal, definitely talk to your sponsor and find out what bend radius they recommend for a given thickness, as this will be driven by the tooling they use. Usually not a huge deal, but updating this after the fact can be somewhat hairy on complex structures depending on how you define your flanges.
Right now, your radii look far larger than what I typically see used for .090" Aluminum, although 6061 vs. 5052 would call for a larger bend radius. Generally, 5052 is recommended for sheet metal work, but some teams do use bent 6061. |
#7
Yes hex chassis designs are going to be very popular in the coming years. Depending the game I wouldn't be surprised to see 50+ next year. However the GDC could easily through a huge obstacle in the middle of the field and make it harder to use standard drive trains.
#9
I would agree, especially considering the incessant whining about high-speed defense this year. dividing the field is the best way to prevent this, though 2012 was too defense-less IMHO
#11
Every team needs to come up with their own opinions but our team won't be doing a multi-sided robot again for the purpose of making it harder to pin us. |
#12
I've done some reworking to remove the gearbox motor plates. The motors now mount directly to the channels which contain the wheel modules. I also added a handy battery mount.
Image found here: http://prntscr.com/3z85k1 |
#13
What are you using to articulate your modules? I can't figure out how you plan to drop the traction wheel.
