Go to Post Thats what makes FIRST so unique how culture and the time is reflected through our bots, but at the same time we all get along...with no problem. - Dan Richardson [more]
Unread 30-07-2014, 22:11
AKSoapy29's Avatar
AKSoapy29 AKSoapy29 is offline
Driver, Prog, Elec, Pneu, Etc.
AKA: Andrew K.
FRC #2169 (KING TeC)
AKSoapy29 has a spectacular aura aboutAKSoapy29 has a spectacular aura aboutAKSoapy29 has a spectacular aura about
pic: Butterfly Drive 2169 Style
Unread 30-07-2014, 22:12
Andrew Lawrence
Posts: n/a
Re: pic: Butterfly Drive 2169 Style
Out of curiosity, how did the butterfly drive work? Did you just rotate the angle of the omni wheel where in on position the traction wheels touched the floor and in the other the omnis were perpendicular with the ground? Or did you somehow manipulate both the traction and the omnis with one module and power them both with the same CIM motor?
Unread 30-07-2014, 22:20
AKSoapy29's Avatar
AKA: Andrew K.
Well I guess the way I would have described our butterfly drive is more just all omni's. The swerve drive modules are anchored in place so they do not turn. We burned out all of our turning motors at state, and that was the last of that. It never worked well in the first place.
I drove the bot on slick tile flooring, and it drifts around quite a bit, but it's a lot of fun to drive. I took it to some carpet, and it handled better.
We will experiment more, and probably post some updates!
Unread 31-07-2014, 00:19
AlecMataloni AlecMataloni is offline
Excellence is Bliss
AlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond repute
I don't want to live on this planet anymore.
Unread 31-07-2014, 01:28
llamadon's Avatar
llamadon llamadon is offline
Gold pants swag
AKA: Quinn
llamadon is just really nicellamadon is just really nicellamadon is just really nicellamadon is just really nice
This is not butterfly haha.
Unread 31-07-2014, 02:28
AKSoapy29's Avatar
AKA: Andrew K.
Haha whoops, just the omni wheel mode from Butterfly
Still, it was interesting to drive; a robot with only omni's on a slick floor. Almost clipped the arm on some things a few t imes
Unread 31-07-2014, 08:33
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
Don't forget the locktite on those WCD gearboxes
Unread 31-07-2014, 10:36
Data Nerd
FRC #0079
Wait, so you were steering omnis? WHY?
More shocking, you burned out steering motors while steering omnis? HOW?
I'm hoping this is a gigantic troll because the level of WTH is way too high.
Unread 31-07-2014, 10:46
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
I believe what happened was they ran traction wheels with their swerve at the MN state tournament and blew out the turning motors there, and then locked the modules in place and ran it as a 4 wheel tank. Then some time later they switched the traction wheels to omnis.
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
Unread 31-07-2014, 10:48
Data Nerd
FRC #0079
Ok, this makes significantly more sense.
Unread 31-07-2014, 12:02
AKSoapy29's Avatar
AKA: Andrew K.
At the start of the season, all of the wheels were 6" KOP wheels, each one individually powered. We couldn't really get the code right, so for state, we added steering linkages, meaning the front pair of wheels were locked together, and the back pair of wheels were locked together. Essentially it had a car steering setup on both the front and back. Well after/during our second match at state, we think the bar flipped around to the opposite side of the wheel, and the encoder detected that, and tried to correct itself, hence burning out all of our motors. The day before state, we changed out the wheels on the shadow bot modules for tank, so we quickly reprogrammed the robot and changed out the modules, took out the turning motors, and locked the wheels in place. Tank has so far worked the best Just for fun, we made all of the wheels omni's, still having them locked in place.
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
I'm guessing they burned out the swerve drive, then swapped the omni wheels in so they could drive it as a 4 wheel drive.
Dang, ninja'd.
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Careful with loctite near those polycarbonate wheels... You'd be much better served with NyLok nuts or similar.
Unread 01-08-2014, 00:51
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
I believe those are vex omni wheels and they are made out of glass filled nylon. I'm fairly confident you can use threadlocker without the risk of melting or cracking plastic.
Edit:
http://www.chiefdelphi.com/forums/sh...1&postcount=16
R.C.
MadTown Robotics Team 1323
Unread 01-08-2014, 08:28
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Edit:
