Go to Post And THAT is why they have safety manuals. - Eria4044 [more]
Unread 28-08-2014, 10:38
jonboy jonboy is offline
Engineer/Mentor
FRC #0885 (The Green Team)
jonboy is an unknown quantity at this point
Recommendations for chain drive lubrication?
Our team is doing some off season overhaul of our competition bot that has been through the mill with normal competitions, lots of practice driving, outdoor street demo, WPI BC, ... Anyway we pretty much neglected the proper care of our 6WD #25 chain drive. We have done some soaking to clean out some of the grime from the chains. The question is what we should use for a lubricant and how often to lubricate? TIA
... jon
Unread 28-08-2014, 11:16
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Recommendations for chain drive lubrication?
I would avoid soaking chains in solvent. It leaches out the lubrication in the pivots where it is difficult to get back into. One way would be to soak it in a hot light weight gear oil then wipe off the excess. Probably a little overboard. You can clean them with a rag lightly soaked in cleaner. Then lube them with a chain lubricant meant for bicycle chain. Wipe off the excess. For chains exposed to dirt & grunge, an argument can be made for little to no lubricant. Or lube often with something like WD40, wiping off the excess. You are mostly lubing the side plates.
Unread 28-08-2014, 11:24
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
I recommend a motorcycle chain lubricant, probably one with molybdenum disulfide in it, such as 'PJ1'. They're designed to stick to high-speed chains where light gear oil won't.
Also, like the previous poster, I don't support ever soaking a chain in solvent to clean it. You'll never be able to get the lube back to the crevices where it was.
Finally, I've not had good experience with #25 chain. Go to #35 if you can. Also, WD40 is okay for a while, but it evaporates. In a month, it won't be there.
As for how often, if you can touch the chain and not get dirty, you probably need to lube again. I lube my motorcycle chain every third day.--200 miles. Oftener is more better.
Unread 28-08-2014, 11:51
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Lack of regular lubrication is one of the most common causes of trouble for many FRC teams. Anything that can make it faster and easier to do makes it more likely to get done. We keep a small paint brush in a ziplock bag with our lube supplies. It is great for re-coating drivetrain chains with a light coat of chain oil. While running the drive very slowly, hold the oily brush (not dripping, just moist) on the chain in a stationary spot (in an open span away from sprockets and pinch points) and you can lightly and evenly lube the chain in just seconds.
Unread 28-08-2014, 11:57
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
We use DuPont Chain Saver. It seems to soak in well, and it dries, so there's not sticky grease or oil for dirt or contaminates to stick to. How often to re-lubricate depends heavily on how much use the chain sees. During competition we would re-lube our drive chains 1-2x a day.
http://i.walmartimages.com/i/p/00/03...83_500X500.jpg
FWIW 95 has had fine luck with #25 series chain, we even used it in our drive-train last year. It is perfectly reliable when implemented properly.
Unread 28-08-2014, 12:07
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Just out of curiosity, what issues have people seen from not lubricating chain? I don't think my team has ever lubricated any of our chains, and we still have our robot from Breakaway (2010) driving around as a practice bot on a regular basis, with the original drive train intact (The drive train and frame are the only parts of that robot that are original... everything else has been replaced for various prototyping/training purposes).
2016: Lake Superior WFFA
Unread 28-08-2014, 12:11
hrench's Avatar
AKA: Bob Hrenchir
When you buy chain, it's already heavily lubricated, but mostly with a heavier grease-type lube. I'm pretty sure an over-designed (too big, like #35) chain would last for hundreds of hours without ever lubricating it.
But is hundreds of hours enough? And the other thing is, the minute someone decides to clean the chain by soaking it, all bets are off. Chains like to be dirty.
Unread 28-08-2014, 12:16
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Simply put - efficiency. When it gets really bad there can be all sorts of issues including: overheating motors, drivetrains that pull to one side excessively, dramatic power loss, and loosening chains.
Lubricating the chains on our 2012 robot's shooter bumped our range up by 20% or so.
donkehote's Avatar
donkehote donkehote is offline
Design/Manufacture/Strategy Mentor
AKA: Kevin
FRC #5031
donkehote is just really nicedonkehote is just really nicedonkehote is just really nicedonkehote is just really nice
There are literally hundreds of teams who run #25 chain in their drivetrain with no issues. #35 is overkill for almost all FRC drivetrains, but it has its place in high reduction arms and such.
2014- 5031 Mentor
2013- 1310 Mentor
2012- 4258 Mentor
2011-2012 865 Mentor
2006-2008 1814 Team Captain, Main Driver, Mechanical
Unread 28-08-2014, 13:25
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Or for lower resource/teams who do not hold tolerances on spacers in the drivetrain. #35 chain is extremely forgiving, in all my years in FRC I've only built one robot without #35 chain in the drive. It may be old school, but its nice to never have to think about it.
We use Dupont TeflonŽ Lubricant to keep all our chains and gearboxes properly lubricated.
Unread 28-08-2014, 15:03
techtiger1's Avatar
techtiger1 techtiger1 is offline
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
techtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond repute
Send a message via AIM to techtiger1
http://www.mobiloil.com/USA-English/...ic_Grease.aspx
This stuff right here. YEAH BUDDY.
Team 1251 The TechTigers
"Inspiring future innovators, one stripe at a time"
2004 Rookie All Star Orlando Regional
2006 Palmetto Regional Winner
2007 Orlando Regional Winner
2008 Orlando Regional Winner
2010 Orlando Regional Winner
2013 South Florida Regional Winner
Unread 28-08-2014, 21:19
donkehote's Avatar
AKA: Kevin
FRC #5031
Originally Posted by techtiger1 View Post
That grease is excellent! What NLGI number do you recommend?
For grease like that, I would probably say #0 or #00 for chains, But I haven't personally run it, so im not sure.
Only downside to using grease on chains is that it can get flung off at speed, and it doesn't really penetrate the side plates unless its thin.
I have run #1 or #2 in gearboxes, but that's a bit thick for chains.
Or for the lowest resource teams, stick with the Kitbot belts, no lubrication, no maintenance, battle tested, simple, comes with instructions and all the parts you need in the kit. If your resources are that low, your time is better spent on things to play the game with.
2014- 5031 Mentor
2013- 1310 Mentor
2012- 4258 Mentor
Last edited by donkehote : 28-08-2014 at 21:34. Reason: Combined 2 posts into 1 for cleanliness
Unread 29-08-2014, 08:44
Engineer/Mentor
Thanks for all the good advice. CD to the rescue.
We have had excellent results with #25 chain by carefully aligning the sprockets and tensioning the chain. The only time we threw a chain was when part of the field fell onto the carpet and our guys drove over it and the metal bracket lodged in the chain derailing it. #35 chain drive system weighs more and is larger volume, overkill IMHO.
As for the soaking, I think we just soaked in a light oil at room temperature, not a true solvent. There was a lot of grime that came off the chain just the same.
As for choosing #25 vs belts: Belts seem to take up lots of volume and I am worried about proper tensioning. Chain length can be easily modified, nothing to order and wait as with belts. Changing out a belt requires a lot more robot disassembly than changing out a chain by removing the master link or popping a pin. The price is right. The chain system may weigh more but the wgt is down low. Belts, however, are quiet.
As for the lubricant now that I think about it, I am sure I got some motorcycle chain lubricant lying around which should be mighty fine for the bot.
Again thanks for the advice. It helped a lot.
... jon
Unread 29-08-2014, 08:58
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
If you want to soak the chain in something to clean it, then try using DRY BICYCLE LUBE...then for typical maintenance lubrication use the wet lube and wipe off the excess. I disagree with the comment "chains like to be dirty..." it is the dirt that eventually kills a chain. A good lubricant will keep the chain clean, which is good for both the life and performance of the chain, and for your members' hands when they are working on it.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 28-08-2014, 12:20
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
If you go with this option often could be close to daily with heavy use. While the exact composition of WD40 is a company secret, it is roughly a mix of mineral spirits & light machine oil. The oil part is persistent as any oil. The solvent helps to penetrate the side plates.
Anything with molybdenum disulfide is going to be messy. One reason why I ride a shaft drive BMW rather than one of the excellent Japanese bikes.
