Go to Post I was watching the webcast when that score was posted and thought to myself, "What did they do, steal a donut from Dave?" - MissInformation [more]
Unread 17-09-2014, 09:22
Ken P. Ken P. is offline
FRC #1189
Ken P. is an unknown quantity at this point
C++ Robot Builder question
The way that RobotBuilder sets up it references is not what I am used to using. I expected to be able to use refer to a RobotDrive method "ArcadeDrive". I typed in "robotDrive41" - the pointer to the instance of RobotDrive and expected to see the methods etc. Instead it complains that it does not know anything about robotDrive41 despite its reference earlier in the file. Any suggestions are appreciated. Here is the code:
#include "DriveTrain.h"
#include "../Robotmap.h"
#include "../Commands/ArcadeDrive.h"
DriveTrain:riveTrain() : Subsystem("DriveTrain") {
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DECLARATIONS
cANJaguar1 = RobotMap::driveTrainCANJaguar1;
cANJaguar2 = RobotMap::driveTrainCANJaguar2;
cANJaguar3 = RobotMap::driveTrainCANJaguar3;
cANJaguar4 = RobotMap::driveTrainCANJaguar4;
robotDrive41 = RobotMap::driveTrainRobotDrive41;
// END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DECLARATIONS
void DriveTrain::InitDefaultCommand() {
// Set the default command for a subsystem here.
//SetDefaultCommand(new MySpecialCommand());
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DEFAULT_COMMAND
SetDefaultCommand(new ArcadeDrive());
// END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DEFAULT_COMMAND
// Put methods for controlling this subsystem
// here. Call these from Commands.
void DriveTrain::arcadeDrive(Joystick stick) {
robotDrive41
Unread 17-09-2014, 14:03
Jefferson Jefferson is offline
AKA: Jeff Clements
FRC #0016 (Bomb Squad)
Jefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant future
Re: C++ Robot Builder question
robotDrive41
I'm guessing you're trying to use the period, as in robotDrive41.TankDrive(Joystick1, Joystick2)
What you need to use is the arrow to reference the functions inside RobotDrive like this...
robotDrive41->TankDrive(Joystick1, Joystick2)
Unread 19-09-2014, 15:17
FRC #1189
Thanks! I had tried it both ways but neither caused the color of the text to change and allow the editor to pull down information on the classes. At least that did not occur until I had saved the changes after using the arrows. When they typed in the text on the WPI RobotBuilder video it seemed to appear faster, so I thought something was wrong. I really appreciate your taking the time to help.
Cheers,
Ken
