Thread Tools |
Rating:
Display Modes |
[FRC Blog] KOP Drive System Opt Out
Posted on the FRC Blog, 10/3/14: http://www.usfirst.org/roboticsprogr...m-Opt-Out-2015
Re: [FRC Blog] KOP Drive System Opt Out
Those profile drawings make me happy. Nice work AndyMark team!
Didn't they give away ground clearance a little bit by showing the chassis profiles.
Even with 8" wheels this chassis would have a hard time having more than 3.75" of ground clearance. Assuming those profile shapes are the only three pieces of the chassis and we don't see a repeat of the 2010 risers. Also climbing ramps and bumps is harder with this chassis than with the previous version that had the angled front and rear rails. |
Good work on AndyMark though for addressing community concerns. 900 has been mounting our transmissions to the inner rail of the chassis for about 3 years now and we were really happy to see the AM14U this past year. I hope it just keeps getting better and better. |
What I'm hoping is that they have an integrated or include pieces for a bumper mount system. I heard that there was some internal discussion at AM about it and I told one of their engineers that from an inspector stand point it would be greatly appreciated. It would make inspection so much easier and save teams so much frustration if we could just say "you used the KOP mounting system per directions" so you are good to go, at least as far as meeting the rules of properly supported and robustly attached.
Also, if the entire front piece were angled, teams would have a heck of a time attaching and properly supporting bumpers!
#9
Yep, the riser kits from 2010. Worked quite well with a standard KOP drivetrain that year. Just putting that out there as a reminder that not all ground clearance has to come from the basic KOP frame.
#10
If the 2015 drivetrain is as similar to the AM14U as they're saying, it won't be able to have risers.
#11
Maybe not an identical part, but what about something which nests between the rails instead of mounting to the bottom? The folks at Andymark are smart guys, they can figure something out if necessary.
#12
This doesn't necessarily imply a completely flat field, 2012 had a similar clearance for 8" wheels but there was still the top hat across the centre of the field.
