Go to Post "Is it possible to cut enough holes in the robot to weight reduce 8 lbs?" - ScoutingNerd175 [more]
Unread 01-11-2014, 12:18
aweso_meme aweso_meme is offline
FRC #4687
aweso_meme is an unknown quantity at this point
Java 2015
Hi all,
I have looked through the internet, however I have not seen anything official put up -- It is all just rumor and speculation. Has a statement been released saying what is new in Java 2015 for FRC or is everything just a guess list?
Unread 01-11-2014, 12:31
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Java 2015
Nothing has been officially released yet. Many teams are beta testing, and the changes aren't that drastic. The biggest change is programming in eclipse instead of netbeans... the API is largely staying the same, with just some tweaks and changes to account for the changed hardware. I haven't really seen any big new features or changes that are going to trip teams up.
When we ported over last year's code to the RoboRio, the students were able to do it all in a single 3 hour meeting.
2016: Lake Superior WFFA
Unread 01-11-2014, 18:35
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Re: Java 2015
Keep in mind that while the API isn't changing this year, Java 8 (SE) will be supported. This is a huge leap forward from what we have now, so there's a lot of extra stuff you can do now.
I would also expect the WPI library to start taking advantage of some of thosee features in future years, though there may not be a whole lot of user facing changes.
Team 2052- Knightkrawler
Mentor and volunteer
Unread 06-11-2014, 21:38
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
Re: Java 2015
The RoboRio will run at least Java 8 SE Embedded for the upcoming season, it is Java 8 SE with Graphical Libraries removed, and other optimizations for a headless, embedded device (low memory). This is obviously pending any official rules. However, If a Java 9 is released from now to kickoff (which is highly unlikely, I doubt FIRST will upgrade to the new JRE because it wouldn't have been vetted through any Beta testing). So in my opinion, it is very safe to assume the RoboRio's will run Java 8 SE Embedded for competition.
The WPI API is changing slightly. There is a list of changes that will be released when the software is released, but none of them are major, and most of your pre-existing code should run without a hitch.
Some classes have been renamed for clarity, numbering has been changed to zero based indexing, etc. Simple Robot is removed in order to prevent rookie teams from using it (because it is harder to use then it seems).
Some libraries have been re-written for better efficiency like the CAN library but the API is largely the same.
The JRE we have been running on the RoboRio for Beta testing is directly downloaded from Oracles Website, so it is not modified by FIRST/NI in any way. You can read what features Java 8 SE Embedded supports on oracles website.
Hope this helps,
Kevin
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
Unread 16-11-2014, 13:36
MJ Miller's Avatar
MJ Miller MJ Miller is offline
Control System Mentor
FRC #4910 (Robohounds)
MJ Miller is an unknown quantity at this point
Re: Java 2015
I'm trying to use the latest Eclipse (Mars Milestone 2 (4.5.0M2), jdk1.8.0_25, and FRC Sunspot Plugin 1.0.8.5. On the surface, installation of all items were successful and I can build a simpleRobot program with no errors. However, I can't deploy due to the following error:
Buildfile: C:\Users\MJ\workspace\mySimple\build.xml
-pre-init:
-do-init:
-post-init:
-warn-jar-file:
init:
-set-selector-for-nonbasestation:
-prim-find-spots:
-checkhasremoteaddress:
-do-find-spots:
-jar-and-deploy:
-pre-init:
-do-init:
-post-init:
-warn-jar-file:
init:
-check-for-manifest:
-set-to-jar-name:
-pre-clean:
-do-clean:
[delete] Deleting directory C:\Users\MJ\workspace\mySimple\build
[delete] Deleting directory C:\Users\MJ\workspace\mySimple\suite
[delete] Deleting directory C:\Users\MJ\workspace\mySimple\j2meclasses
-post-clean:
clean:
-pre-compile:
-do-compile:
[mkdir] Created dir: C:\Users\MJ\workspace\mySimple\build
[javac] Compiling 1 source file to C:\Users\MJ\workspace\mySimple\build
[javac] warning: [options] source value 1.3 is obsolete and will be removed in a future release
[javac] warning: [options] target value 1.2 is obsolete and will be removed in a future release
[javac] warning: [options] To suppress warnings about obsolete options, use -Xlint:-options.
[javac] 3 warnings
-post-compile:
compile:
-pre-preverify:
-make-preverify-directory:
[mkdir] Created dir: C:\Users\MJ\workspace\mySimple\j2meclasses
-unjar-utility-jars:
-do-preverify:
-post-preverify:
preverify:
-pre-jar-app:
-do-jar-app:
[mkdir] Created dir: C:\Users\MJ\workspace\mySimple\suite
[jar] Building jar: C:\Users\MJ\workspace\mySimple\suite\Robot_1.0.0.j ar
-post-jar-app:
jar-app:
-set-from-jar-name:
-check-for-jar:
-pre-suite:
-do-suite:
[java] CompilerOracle: exclude com/sun/squawk/Method.getParameterTypes
[java] CompilerOracle: exclude com/sun/squawk/SymbolParser.getSignatureTypeAt
[java] CompilerOracle: exclude com/sun/squawk/SymbolParser.stripMethods
[java] [translating suite image [closed: false, parent: squawk] ...]
[java] ### Excluding compile: com.sun.squawk.SymbolParser::getSignatureTypeAt
[java] ### Excluding compile: com.sun.squawk.Method::getParameterTypes
[java] [Including resource: META-INF/MANIFEST.MF]
[java] Romizer processed 97 classes and generated 4 files.
[unzip] Expanding: C:\Users\MJ\workspace\mySimple\suite\Robot_1.0.0.j ar into C:\Users\MJ\workspace\mySimple\suite
[move] Moving 1 file to C:\Users\MJ\workspace\mySimple\suite
[delete] Deleting: C:\Users\MJ\workspace\mySimple\image.suite.api
-post-suite:
-prim-find-spots:
-do-find-spots:
-pre-deploy:
-failIfRemote:
-do-upgrade:
Host OS: Windows 7 6.1, 6.1
Host JVM: Java HotSpot(TM) 64-Bit Server VM 25.25-b02
Target IP: 10.49.10.2
Network interfaces on host:
Intel(R) Centrino(R) Wireless-N 2230: address: 192.168.1.70 netmask: 255.255.255.0
Realtek PCIe FE Family Controller: address: 10.49.10.5 netmask: 255.0.0.0 <--- on robot's subnet
[frcupgrade] Connecting FTP @10.49.10.2
BUILD FAILED
C:\Users\MJ\sunspotfrcsdk\build.xml:96: The following error occurred while executing this line:
C:\Users\MJ\sunspotfrcsdk\ant\upgrade.xml:40: java.lang.NullPointerException
Total time: 7 seconds[/font][/font][/font][/font]
The error points to upgrade.xml:40 and suggests some configuration problem exists. I have followed 3 different sets of instructions from WPI and teams with all yielding the same error above. What configuration step have I missed?
build.xml:95-97
<target name="-jar-and-deploy" unless="from.jar.file">
<antcall target="-do-jar-and-deploy" />
</target>
ant/upgrade.xml:29-42
<target name="-do-upgrade">
<frcupgrade
remoteaddress = "${remoteaddress}"
localotaserverfile="${sunspot.home}/cRIO/FRC_UserProgram.out"
remoteotaserverfilepath="/ni-rt/system/FRC_JavaVM.out"
localvmfile = "${sunspot.home}/cRIO/squawk.out"
remotevmfilepath="/ni-rt/system/squawk.out"
localsuitefile = "${sunspot.home}/cRIO/squawk.suite"
remotesuitefilepath = "/ni-rt/system/squawk.suite"
remoteversionfilepath = "/FRC_ImageVersion.ini"
versionfailuremessage = "Go to http://first.wpi.edu/FRC/frcjava.html to get latest software update"
<version name="Name" value="FRC_2012_v43.zip;"/>
<version name="Language" value='"Java;"'/>
Also, I noticed the wpilibj that gets installed with the plugin is missing some items namely Talon.class and LiveWindow.class and some others. Perhaps this version of wpilibj is dated. The getting started with Java manual lists a procedure for building a custom library using Netbeans. I have the wpilibj.project.zip archive, but there is no project file to open as the procedure instructs. I don't really need a custom library, but just looking for a way to get this setup working.
Unread 16-11-2014, 13:51
Controls Engineer
AKA: Kevin
Re: Java 2015
The offiical eclipse plugins for the Roborio have not been released yet.
There are no official eclipse plugins for the cRio. It sounds lile you installed an old beta eclipse plugin released in 2011 by first that was never maintained or updated (thats why all of the classes ypu mentioned are missing).
If you are trying to use eclipse with the cRio and 2014 java wpilibj, I suggest you start over and follow my previous guide on how to do that. http://www.chiefdelphi.com/forums/sh...d.php?t=110420
The link is for 2013, but it is exactly the same for 2014, just need to steal the 2014 jars from either netbeans or our download page.
If you are wishing to find the 2015 plugins, for the Roborio, you will have to wait until kickoff for that to be released... only beta teams have early access to the 2015 eclipse plugins for testing purposes.
Regards,
Kevin
Unread 16-11-2014, 15:06
MJ Miller's Avatar
Re: Java 2015
Thanks Kevin! I appreciate it.
MJ
