Can someone explain this code?
Could someone explain what is going on in this code?
public class Drivetrain { Talon talon1 = new Talon(1); Talon talon2 = new Talon(2); Talon talon3 = new Talon(3); Talon talon4 = new Talon(4); Talon talon5 = new Talon(5); Talon talon6 = new Talon(6); DoubleSolenoid shifter = new DoubleSolenoid(1, 5, 6); Encoder leftEncoder = new Encoder(10, 11); Encoder rightEncoder = new Encoder(13, 14); public Drivetrain(){ leftEncoder.start(); rightEncoder.start(); } //DigitalInput port14 = new DigitalInput(14); public void arcadeDrive(double moveValue, double rotateValue){ double leftMotorSpeed = 0, rightMotorSpeed = 0; rotateValue = -rotateValue; moveValue = limit(moveValue); rotateValue = limit(rotateValue); if (moveValue > 0.0) { if (rotateValue > 0.0) { leftMotorSpeed = moveValue - rotateValue; rightMotorSpeed = Math.max(moveValue, rotateValue); } else { leftMotorSpeed = Math.max(moveValue, -rotateValue); rightMotorSpeed = moveValue + rotateValue; } } else { if (rotateValue > 0.0) { leftMotorSpeed = -Math.max(-moveValue, rotateValue); rightMotorSpeed = moveValue + rotateValue; } else { leftMotorSpeed = moveValue - rotateValue; rightMotorSpeed = -Math.max(-moveValue, -rotateValue); } } //Setting talon values talon1.set(-rightMotorSpeed); talon2.set(rightMotorSpeed); talon3.set(rightMotorSpeed); talon4.set(leftMotorSpeed); talon5.set(-leftMotorSpeed); talon6.set(-leftMotorSpeed); } protected static double limit(double num) { if (num > 1.0) { return 1.0; } if (num < -1.0) { return -1.0; } return num; } public void highGear(){ shifter.set(DoubleSolenoid.Value.kReverse); } public void lowGear(){ shifter.set(DoubleSolenoid.Value.kForward); } public void brake(){ } public int getRightDistance(){ //return port14.get(); return rightEncoder.get(); } public int getLeftDistance(){ return leftEncoder.get(); } public void resetEncoders(){ leftEncoder.reset(); rightEncoder.reset(); } } |
Re: Can someone explain this code?
What behavior is it exhibiting that doesn't make sense?
It looks relatively normal, but could you add code tags around it so it preserves indentation? e.g. Code:
printf("Hello World");
[ /code ] closes (Eliminate the spaces from the tags) Last edited by JesseK : 04-11-2014 at 18:28. |
The code works fine, I just don't understand it and I am unable to contact the guy who wrote it.
The code shown is for a 6 wheel west coast drive bot |
Here's what I've interpreted so far. The rotate left/right may be flipped.
This is a rather strange convention. leftMotorSpeed = moveValue - rotateValue; rightMotorSpeed = Math.max(moveValue, rotateValue); It's probably trying to make sure the right motor is going faster than the left (i.e. turning left), but regardless this is probably not the ideal way to code this. Code:
//right speed controllers
Talon talon1 = new Talon(1); //front
Talon talon2 = new Talon(2); //middle
Talon talon3 = new Talon(3); //rear
//left speed controllers
Talon talon4 = new Talon(4); //front
Talon talon5 = new Talon(5); //middle
Talon talon6 = new Talon(6); //rear
rotateValue = -rotateValue; //x axis value from joystick. inverted to get the correct rotation direction
moveValue = limit(moveValue); //y axis value from joystick. make sure its between -1 and 1
rotateValue = limit(rotateValue); //make sure the rotation value from before is between -1 and 1
//driving forward?
//turning left?
} else {
//stopped or turning right?
} else {
//driving backward or stopped
//turning left?
} else {
talon1.set(-rightMotorSpeed); //invert the front right speed controller (probably because the leads were swapped)
talon5.set(-leftMotorSpeed); //invert the center left speed controller (probably because the leads were swapped)
talon6.set(-leftMotorSpeed); //invert the rear left speed controller (probably because the leads were swapped)
if (num > 1.0) {
return 1.0;
if (num < -1.0) {
return -1.0;
return num;
//retract pneumatic
//extend pneumatic
From a style and code neatness standpoint, might I suggest putting your right talons in an array and your left talons in another? Then you can set an entire side's speeds with a for loop like so:
for (int i = 0; i < left.length; i++)
left[i].set(1);
for (Talon t : left) t.set(1); Code:
public void setLeft(int speed)
t.set(speed);
public void setSpeed(Talon[] tarray, int Speed)
for (Talon t : tarray)
t.set(speed);
if (t.equals(talon1) || t.equals(talon5) || t.equals(talon6))
t.set(-speed);
else
t.set(speed);
