Go to Post The real key to drive team coaching is to tie your jacket around your waist. Got a couple championship rings that way. - TravusCubington [more]
Unread 17-11-2014, 09:47
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
How to do calculations with a 2 CIM, 1 Mini-CIM gearbox?
Hi CD,
I've been working on drivetrain designs lately and I've been looking into using a 2 CIM, 1 Mini CIM gearbox. I've been told by people from multiple teams that this is ok to do and that I shouldn't have to change the pinion gear on the mini CIM. Can someone help me figure out things like torque and free speed of a gearbox like that? I don't really know how to find gearbox calculations besides just plugging into JVN Calculator, so I'd like to learn how to calculate it.
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 17-11-2014, 09:57
Knufire Knufire is offline
Re: How to do calculations with a 2 CIM, 1 Mini-CIM gearbox?
Look at the excel sheet and associated presentation by Paul Copioli here: http://www.fightingpi.org/Resources/...Seminars.shtml
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 17-11-2014, 09:58
Originally Posted by Jay O'Donnell View Post
Hi CD,
Add the torques.
Free speed is given by the formula (T1+T2+T3)/(T1/S1+T2/S2+T3/S3),
where Tn, Sn is the stall torque and free speed of motor "n".
Unread 17-11-2014, 10:30
Add the torques.
... or you can plot the torque vs speed curve of each of the three motors, plus the sum of the torques vs speed, and see where the sum crosses the speed axis.
Unread 17-11-2014, 15:06
Oblarg Oblarg is offline
AKA: Eli Barnett
Edit: Disregard, figured it out.
"The breakfast of champions!"
Unread 17-11-2014, 15:15
Originally Posted by Oblarg View Post
I'm curious - how does one derive this?
http://www.chiefdelphi.com/forums/at...0&d=1387494073
Unread 17-11-2014, 18:21
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Depending on your desired level of accuracy...
When I need quick & dirty:
I use a MiniCIM as 0.6 of a CIM. So for the gearbox you're describing I'd plug 2.6 CIM motors into my spreadsheet for 2 CIMs + 1 MiniCIM.
This has been close enough for most of the quick design work used during an FRC season. I save the more detailed analysis for the times I need it.
-John
PS - Paul, Ether & Richard, please don't revoke my "allowed to talk about motors" privileges.
Unread 17-11-2014, 22:07
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
There is a rich tradition in engineering of celebrating prolific contributors by naming standard physical units after them. For example, the unit of electrical capacitance is named for Michael Faraday, and the unit of power transfer/conversion is named for James Watt.
I propose naming the fundamental unit of FRC drivetrain "oomf" in honor of JVN.
Let's say the "oomf" of a well designed four CIM drivetrain is one JVN. Then by the approximation John proposed above, a well designed drivetrain with four CIMs and two mini-CIMs will deliver 1.3 JVN of "oomf", while a well designed six CIM drivetrain is good for 1.5 JVN.
Your oomf may vary.
Richard Wallace
since 2003
Unread 17-11-2014, 22:09
AdamHeard's Avatar
Lead Mentor
Your oomf may vary.
The resistance of the battery makes the 1.5 JVN number a bit idealized though
Unread 18-11-2014, 10:04
Division by Pirates
-John
On an unrelated note, what do you use as your input for coefficient of friction?
Unread 18-11-2014, 10:40
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Depends on your wheels. Which are you using?
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 18-11-2014, 13:51
Division by Pirates
For the design I'm currently working on, 4"X1.5" Colsons.
Unread 18-11-2014, 13:53
JVN JVN is offline
@JohnVNeun
+1
I haven't done traction testing on those in years. I think they are around 1 - 1.1
Unread 18-11-2014, 16:22
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
Is there any benefit of using a different pinion on the minicim to get the free speeds closer together?
Unread 18-11-2014, 16:57
It depends on what you want the motor combination to do, and what the duty cycle is on the combined motor curve.
