2015 FRC prototype two speed swerve drive first run
https://www.youtube.com/watch?v=T0lR...ature=youtu.be
As the title states, the very first time this bot has moved! This is only with a few hours worth of coding so it's barley functional(in fact it's just partially functional, there is still no rotation!) and highly untuned. so far things look very promising. The whole point of this test to see how fast it would go and how the shifting behaved. The reason it fell apart at the end was because an untightened screw came undone from a retention shaft so the gears kind of just flew out. As you can tell the speed is great, you can clearly tell when it's in low and high gear from the sound it makes and the speed it goes. The shifting works great too but under high stress we need more pressure so we will be upgrading the 3/4" pistons to a bigger bore. With a few weeks worth of programming and tuning it should perform beautifully. Longevity is still yet to be determined but so far we are VERY happy and excited about it. This is as rough as it can possibly be, only going to improve going forward. |
Re: 2015 FRC prototype two speed swerve drive first run
What's you resoning behind 6" wheels over 4" ones? Smaller would also decrease the required piston, so you could keep your current ones.
Looks really good. You could go faster in high gear if you wanted I think, but it's your call. |
we can indeed go faster, or have more power. This was just a starting point. we can even adjust these factors between matches if we wanted to depending on the opposing alliance by changing the sprocket sizes! talk about versatility! |
Gears are more efficient than chain, but they are less versatile. |
ah yes that reminded me of the reason! we went with big wheels for potential obstacles. It's easy enough to design down but not so much to design up. If it's a flat field then we will probably use small wheels but for now we're going big in case there is anything where it's advantageous to go with big wheels like obstacles or game pieces. If that's not needed then we can pretty easily shrink the design down accordingly
Congrats on getting a working (mostly) system built in the fall! Start working out your code issues now, there is hardly any time for that come January 3rd. Best of luck! -Mike |
#7
There are a lot of swerve codes out there floating around for all types of control configurations. If you get stuck look at some of them.
#8
I know you said you may change it, but for reference what speeds is it geared to in the video?
#9
low gear is 16 to 1 and high gear is 8 to 1. with a 6" wheel. but as stated we can fine tune or drastically change that with changing the chain sprockets. we think we like these ratios though.
#10
Those poor gears. What did they do to deserve such treatment?
#11
so yea that was all our, or rather i should say my, fault. but it's ok! nothing broke so after break we can resume more testing and abuse of the system! after a lockwasher and locktite that is xD and probably that pin as well... I kind of like that it failed and how it failed, it adds a bit of humor at the end xD |
#12
Source: A rather in depth debate with John about it. |
#14
coding is no issue really i just need sufficient time to work on it. in the videos that's just a few hours worth of code so given a reasonable amount of time i can get it working pretty good ![]() |
