Go to Post We're still not ready for 2012.... - AdamHeard [more]
Unread 01-12-2014, 10:04
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
pic: 3 CIM WCD Ball Shifter CAD
Unread 01-12-2014, 10:06
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
Re: pic: 3 CIM WCD Ball Shifter CAD
Those ratios are just about perfect.
Have you considered trying to make the Cims or shafts removable to facilitate easy gearbox removal?
Also, you may want more than just the two holes in the WCD block to mount the gearbox to the tube. Two more holes higher up on the gearbox would add a lot of strength.
Unread 01-12-2014, 10:40
jagoldman jagoldman is offline
jagoldman
AKA: jagoldman
FRC #2972 (RC Dawson)
jagoldman is an unknown quantity at this point
That is a great looking gearbox!
I have a few questions though...
1) How much does it weigh?
2) What are the actual gears that are being used? The tooth count would be good, no need for product numbers.
3) How do you plan on mounting the gearbox?
Unread 01-12-2014, 10:57
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
It is as if Bryce's and R.C.'s two minds are like one. All that's missing are wave washers and an adjustable CIM mount for multiple CIM pinion options. The standoffs are slightly nested into the side plates for extra alignment support, but that's probably optional if there are other supports.
This makes me wonder if we can simply replace the output shaft and output gears on the WCP gearbox with their ball-shifting counterparts to get something that works with minimal modifications.
Unread 01-12-2014, 11:14
Olin class of 2019
Why would you do that? What advantages do ballshifters have?
I seem to recall that ballshifters wear out faster ,but I could be wrong there.
Unread 01-12-2014, 11:23
JesseK's Avatar
FRC #1885 (ILITE)
Faster shift-on-the-fly. Yet I agree there are tradeoffs, and I don't me to imply I'm entertaining executing the idea, but rather mulling over its possibility.
Unread 01-12-2014, 11:51
Chris is me's Avatar
AKA: Pinecone
I think the lightening on the plates is just a bit too aggressive. Reducing weight is nice and all but you still want to keep your gearbox rigid and strong. I would thicken the webs and probably add another horizontal web(s) between the edge and the bearing for the first reduction. Just seems like not a lot of support to me. If you're that desperate to save a couple of ounces, lighten the gears before you lighten the sideplates that aggressively.
I would also be concerned about how little you are supporting the top CIM on this gearbox.
Unread 01-12-2014, 13:16
AdamHeard's Avatar
Lead Mentor
I have my doubts about the press fit into the end of the ballshifter shaft in such a configuration.
Unread 01-12-2014, 13:40
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
The Cims are already removable. (although not very easily) I've considered making the gearbox removable, but I haven't come up with anything slick yet.
It weighs 1.9 lbs without motors and 10.5 with them according to inventor.
First stage is 12 to 54, second stage low is 24 to 60, and second stage high is 40 to 44.
It's mounted with the standard bearing block and the two bolts the are out to the sides.
The VEXpro ballshifter has a small aluminum shifting rod that tends to wear out. In this design, we would make out own out of steel for longevity.
That's just how I roll. If we're already going to be milling out the plates, why not optimize for the lowest weight reasonable?
This uses a simple one piece output shaft. Machinable on a manual mill and lathe.
Thanks for all the great responses! Keep it up!
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 01-12-2014, 13:42
AdamHeard's Avatar
Lead Mentor
Can you post a cross section of the shifting then?
Curious how that assembles if you've replaced their setup.
Unread 01-12-2014, 13:54
AKA: Pinecone
What I am saying is that your weight right now is potentially lower than reasonable. As you remove so much material, the gearbox becomes less rigid, and stuff will deflect away from each other under load. The CIM mounting is especially concerning as the moment applied by the mass of the motor will tend to bend the pinions away from the cluster gear, weakening both of them.
There's no reason to lighten a gearbox so aggressively when you have all that extra material in your gears that serves so much less function than the material you've removed from the gearbox. You could still have a heavily lightened gearbox, with just more material and better motor support. You would probably even have a net weight loss if you faced the gears and drilled some holes in them well below the root of the teeth in addition to adding material to the gearbox.
Unread 01-12-2014, 14:09
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
I don't see how the top motor is mounted less securely than the top motor of the WCP 3 CIM DS gearbox. In this design the plate is thinner, but the upper standoffs are closer to the CIM.
If I was going to lighten the gears, I would lighten them as much as reasonable too, but that is a different story.
Unread 01-12-2014, 15:50
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
The two lower bolts on the gear box should be able to go through the tubing used on drive rail. You would drill a clearance whole on the outer wall and the correct size on the interior wall.
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
Unread 01-12-2014, 16:33
Olin class of 2019
Might just be the angle of the render , but it to me looks like those 4 bolts are in a horizontal line. This won't help; the weight of the gearbox and CIMs would be cantilevered on those 4 bolts. Adding 2 bolts above or below those 4 will add much more strength.
Unread 01-12-2014, 17:09
Jared's Avatar
Jared Jared is offline
I modified my gearbox plate to look more like yours and did a simple factor of safety analysis. A lower factor of safety corresponds to more load on the material, and a greater deformation of the part.
You could likely get away with what you have drawn up, but some simple improvements will yield huge strength increases. The biggest change you should make is using the 0.75" boss on the front of the CIM to help locate the CIM. It'll increase the positional accuracy of the CIM by quite a bit, and it'll make the part even stronger.
All tests were done with the the mounting holes as fixed geometry, and the only load was gravity acting on the 2.82 pound CIM motor. You can roughly double the strength of the part while adding about 0.03 pounds.
You can also see why having a convex outline helps too.
http://imgur.com/a/xTIpW
This is what we came up with last year for a 3 CIM configuration:
http://imgur.com/DSjie1M
