Go to Post Just because its a robotics competition does not mean everybody is a big dork. - Taxi Quinn [more]
Unread 02-12-2014, 21:36
MrRiedemanJACC MrRiedemanJACC is offline
FRC #2611 (Jacktown Vectors)
MrRiedemanJACC will become famous soon enough
Concept 8 Wheel West Coast Drivetrain
In my engineering class I have had several students working on a concept drivetrain that we are hoping to build before the season starts. We really like using 80/20, so that's what we started with on the frame. We have our 3-D printed corner pieces on it along with new motor and wheel mounts. It's a 6 CIM direct drive to one wheel and belt drive to the other 4" Vex Wheels. We have the VEX shifting gearbox in it geared for 22 FPS and 10 FPS (wanted to go slower, but they were out of stock of one of the gears we needed - but I believe they are in now, so we'll get those in soon, swap them out and we'll be at 18.1 and 8.4 or 6.9 if we go with the different ratio). We don't have the pneumatic cylinders in it just yet, but will hopefully by the end of the week. Also, if you happen to have seen the 118's drivetrain, we based it off of that concept.
If you have any suggestions or questions let us know!
Also, I tried to include this in the Extra - Discussion forum, but I wasn't able to. I hope this is the correct location for this thread.
ID:	17536  Click image for larger version
Unread 03-12-2014, 09:40
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Re: Concept 8 Wheel West Coast Drivetrain
Could you post higher resolution picture possibly? I'd like to see what you did with the sliding wheels. From what I hear tensioning belts properly is really finicky, so if you're just planning on pulling the wheels apart by hand until they 'feel' tight enough you might want to come up with a more repeatable system.
Also what are the switches with rollers attached near the center wheels used for? At least from the picture they look like switches.
Total weight with what you have in the picture?
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 03-12-2014, 10:56
They look like switches, but these wheels will actually actuate with pneumatic cylinders. The front will actuate together and the back will actuate together, but independent of the front. This should help with turning and maneuverability. (at least in theory, we need to test it though). (see this video for how we are hoping to make it work https://www.youtube.com/watch?v=PtRewwr59d8 )
We'll get an updated render up also. We are new to rendering in Solidworks (making the change from Inventor) so we are a little rusty.
As far as tensioning goes we are going to use the measurements from the online calculators to drive our distances. If we have to, we can make "positive stops" between the pieces and mount to the 80/20 to set the distances.
Unread 03-12-2014, 12:37
Here's a better render.
Name:	3 updated.JPG
