Go to Post Pompous boasts dont get you anywhere. Results get your name on the book... - Jeremy_Mc [more]
Unread 04-12-2014, 22:21
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Swerve Programming Spreadsheet
We're planning on making a Robot-Oriented Drive system this year (game willing). In this process it became obvious that programming is a bit tricky, so we made a spreadsheet that takes X,Y,and Rotation values and gives each of the 4 wheel orientations and speeds.
The spreadsheet was made such that you should be able to follow step by step through the calculations and translate it to programming.
Enjoy, and pass along any suggestions or questions.
-Matt
Unread 05-12-2014, 01:57
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Swerve Programming Spreadsheet
-Matt
Very cool! Saved to my computer to peruse later.
Unread 05-12-2014, 09:16
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
There is a very detailed set of papers and a simulation spreadsheet available here as well...
More is more.
Ether's Swerve Stuff
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 08-12-2014, 12:50
mr. giggums mr. giggums is offline
AKA: Bennett Bernardoni
FRC #2451 (PWNAGE)
mr. giggums is on a distinguished road
The method used in the spreadsheet seems slightly incorrect and will give some wrong numbers. One of these cases is when Joystick Y = 1 and Rotation = -1. The spreadsheet will give the following results.
	Angle 	Power
Wheel 1 270.00	0.45
Wheel 2	333.44	1.00
Wheel 3	26.57	1.00
Wheel 4	90.00	0.45
The robot will look as follows (where the length of the arrow roughly equals the power).
In the image above the robot might seem to move correctly but the wheels will scrape across the ground and will lose a lot of power. The robot should look like the following.
This is caused by a slightly incorrect algorithm. For a correct algorithm I would heavily suggest that you look at Ether's swerve stuff as posted above, specifically, the first attachment.
Also, the way you deal with scaling the power values is incorrect. The two following cases give the same results.
Joystick Y = 0.1 and Rotation = -0.1
To solve this problem you need to take the power values and multiply by the maximum magnitude of the joysticks.
Unread 08-12-2014, 21:29
FRC #6054 (Dukes)
Mr. Giggums
Thanks for taking a look. I went back to my sheet and found 3 errors. First I had switch wheels 3 & 4 on the layout diagram. Second I had weighted both the X and Y components of rotation at 1.0 which gives a total resultant of 1.41 which makes the vector from rotation too heavily factored into the overall resultant. I corrected that and the weighting to .707.
I also found the problem with scaling. Turns out that I was scaling the numbers so max motor value was 1.0. I changed it so it only scales if a motor value is >1 now.
Thanks for checking it for me. It seems to correlate pretty well to Ethers numbers now.
I'll attach a new version with corrections for anyone whose interested.
