Go to Post Why is it OK to be "elitist" when we select people to be on a team to hit rocks with sticks, but not OK when we try to reach the special group of students that embody the intellectual capital that will define the future of this country? - dlavery [more]
Unread 09-12-2014, 16:30
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Designing for Powder Coating
We have a new sponsor that is willing to do powder coating for us, so we're considering having our robot parts powder coated this season. For teams that have been doing this for years, what pointers can you give for designing a robot that is ready to be powder coated?
  • Do you make dimensional allowances to account for the powder thickness?
  • What kind of cleaning or surface prep is required before sending your parts out for coating? Do you mask off certain things?
  • What kind of "clean up" is required after you get your powder coated parts back? Are bolt clearance holes OK or do they need to be reamed, tighter tolerance things like bearing pockets, etc?
  • Any other words of wisdom?
Thanks.
Unread 09-12-2014, 16:50
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Re: Designing for Powder Coating
Last year, 2220 had our chassis powdercoated by one of our sponsors. We certainly haven't been doing powdercoating for a long time (I'm hoping to see 254 get in on this thread), but there were a couple of things we learned:
For hole tolerances, if we dimensioned it as a clearance hole, it was completely fine (we just used the clearance hole setting in Creo for that hole size, you can look up whatever size that gives you to find drill bits for that size, otherwise if you're having a CNC sponsor do that for you they should be able to easily recognize it).
We didn't do any major surface prep because our sponsor handles ridiculous volumes of powdercoated parts, so they basically have the entire process from intake through application to baking automated.
For dimensional tolerances, powdercoats can vary in thickness, so talk to your sponsor-- depending on the application method, they can be 1 mil to 10 mil in thickness* (though in our experience it tended towards the lower end of that). Definitely talk to your sponsor about their recommendations.
*might be wrong on this, main point is that it varies
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 09-12-2014, 16:54
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
    Yes - varies by vendor. We have seen thicknesses up to .030 per surface, but usually see .010 or thinner per surface. Don't forget about both sides of a part.
    Depends again on vendor. Many will sandblast and clean the surface for you. We always clean the oxidation off welds, but leave everything else. Our sponsor sandblasts most of our parts.
    Minimal based on item 1. Plan ahead for build-up and you can minimize clean-up. Some holes can be easily reamed, etc. Ideally mask bearing bores or do not powdercoat parts with tolerance critical bores, etc. We anodize these parts unless the anodize won't match the desired aesthetic. Reaming or masking bearing bores never comes out nicely. Avoid it if possible. The last few years we have powdercoated fewer and fewer parts based on the re-work time to ream and clean out bearing bores. I do not recommend trying to guess the powdercoat thickness for bearing bores and machining them larger prior to powdercoating. This is risky. Threaded holes can go two different ways. You can ask for the holes to be plugged (which might leave a rough edge right at the thread), or you can chase the threads with a tap after the fact. If it is something simple like a baseplate/bellypan, you can always drill it larger and tap it after powdercoat, using smaller holes as a drill guide for locations.
    Talk to your sponsor. They can better answer all of these questions for you based on their experience and their willingness to walk you through the process/address issues before you get the parts back. You'll also figure out most of this stuff the first few times you do it. Some of it comes with practice.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 09-12-2014, 17:39
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
If you add or modify parts after the powder coating is done, they won't be powder coated.
We PC with black, so using black spray paint for added parts doesn't look to bad
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 09-12-2014, 17:48
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Unless, like Team 11, you powder coat and bake the parts yourself.
Then you only see that if the part was thrown together or made on the road.
You do need to consider the hole sizes if you allow the powder to get into the holes.
Team 11 uses sand paper, grinds, sand blasts and masks parts as preparation.
Unread 09-12-2014, 18:29
Chadfrom308's Avatar
Chadfrom308 Chadfrom308 is offline
Slave to the bot
AKA: Chad Krause
FRC #0308 (The Monsters)
Team Role: Driver
Chadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to behold
We got it for the first time last year. We didn't do any preparation, it was a kind of a last minute thing. Unless your robot needs super tight tolerances, it wont make a difference. We had had to drill out a few holes for rivets because they were tight. But other than that, I don't think we did much else. We didn't weld, so we powdercoated literally everything with no tape or whatever to keep areas clear.
Unread 10-12-2014, 02:12
craigboez's Avatar
Mechanical Engineer
For teams that use a WCD chassis, do you make any specific allowances for the pockets in the siderail that the bearing blocks ride in?
Unread 10-12-2014, 02:35
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We do. I absolutely hate having to file/sand off powder coat. So, we put in an allowance for it. More importantly, we make our axles a little longer too. I can never remember how much the allowance was, and every year, we have to look back at the previous year's robot or CAD model.
This is something we need to add to our internal Standard Operating Procedure.
Unread 10-12-2014, 07:44
Allison Allison is offline
AKA: Allison Phelps
FRC #1024 (Kil-A-Bytes)
Allison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant future
Another thing to note if you are doing a light color (say fluorescent yellow) things like sharpie and the material call out printed on your parts will show through your powder.
Like 254 we anodize all tight tolerance parts.
For clean up we have found that rivet holes especially 1/8" have to be reamed. Masking parts typically makes for a cleaner look than sanding/filing off powder.
Unread 10-12-2014, 13:56
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I believe we add .015 to the cutouts on our frame.
2001-2004: Team 100
2006-Present: Team 254
Unread 11-12-2014, 16:49
GDB's Avatar
GDB GDB is offline
AKA: Garrett
FRC #2403 (Plasma Robotics)
GDB is a jewel in the roughGDB is a jewel in the roughGDB is a jewel in the rough
Our sponsor sandblasted it for us, so yeah just find a sponsor that would be willing to do that, or sandblast it yourself.
When we powder coated our arm, we had to cut off part of the underneath of the catapult arm, so as long as you get it clean cut and nice looking you won't need to powder coat it because we still got the Imagery award and Engineering Inspiration and Regional winner all in one Regional.
Unread 24-12-2014, 11:12
craigboez's Avatar
Mechanical Engineer
Has anybody weighed their chassis before and after powdercoating - how much weight should I expect it will add?
Unread 25-12-2014, 02:23
75vs1885's Avatar
75vs1885 75vs1885 is offline
AKA: Stephen
FRC #1885 (Ilite)
75vs1885 will become famous soon enough
When I was dealing with powder coating, 1885, I would just drill the hole over again, the little powder coating that was in the hole would come right off.
You can also ask the person not to put any powder in the holes....that's probably the easiest thing.
But if you take a bolt and thread it through then it would probably come off itself.
Alumni from 75 and 1885
Unread 25-12-2014, 02:38
Tyler2517's Avatar
Tyler2517 Tyler2517 is offline
ShortOnes
AKA: Tyler Gibb
FRC #2517 (Evergreen Robotics)
Tyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura about
Out of curiosity who is the sponsor? I am local and am wondering about getting some personal parts powder coated.
Unread 25-12-2014, 10:12
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Keep in mind when powder coating you must use high heat masking tape. For masking holes I have found silicone tapered plugs work best.
