Go to Post We should also remember the fact that the FIRST Manual is not supposed to be enterpreted with lawyer speak. If so you could make it say many things. - Anthony [more]
Unread 30-12-2014, 13:22
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
pic: manually machinable swerve from 2471
Unread 30-12-2014, 13:23
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: pic: manually machinable swerve from 2471
Nice. With so many advanced (and amazing) swerve systems out there its nice to see fundamentals being produced.
Now if we just had a mill at our school...
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 30-12-2014, 13:58
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Will you release a CAD model?
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 30-12-2014, 14:08
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
I didn't CAD the caster portion and I don't know where it is, but when I get my hands on it, I'll try to post the designs.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 30-12-2014, 16:51
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
Looks good! For the bearing holes was it drilled, then reamed or just drilled?
(2015-?): 973
(2012-2015): 955
Unread 30-12-2014, 20:12
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
That looks like a neat layout, with the drive belt actually going around the steering motor; it allows for a lower COG than most swerves I've seen. If a low COG (and profile) is a real driver, though, is there enough room for the steering motor below the "gearbox"? With steering motors below the box, I could see this as a great low-profile, low-COG, easily machinable swerve - and probably as one which could be downgraded to crab drive by orienting the boxes radially and running belts or chains annularly.
Is there a chain in the caster section? There doesn't seem to be enough room for a belt (much less a bevel gear) on the wheel axle.
Unread 30-12-2014, 21:17
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
OK, I'm just going to spitball what seem to be the best ways to make this really hand machinable on a drill press (which is the best tool my team has)..
1) Both the caster box and the gear box are made from large aluminum box extrusions, allowing for drill-press alignment of pilot holes on opposite sides of the shafts. -- and drill the caster axle before cutting!
2) use a chain, not gears, between the two axles in the caster box, allowing a much coarser tolerance for spacing than gears would allow.
3) both bevel gears would be held in place on their shafts with set screws or shaft collars, allowing post-drilling alignment.
4) as for #2, a belt or chain connection between the steering motor and the caster box, probably inside the gearbox.
5) a triple bearing around the main drive shift:
a) one radially supporting the drive shaft in the "gear box"
b) one radially supporting the drive shaft within the caster box
c) a thrust bearing supporting the gear box above the caster box
If I were doing this, I would probably make the gearbox much flatter so it just held the steering belt/chain/gears, or move the drive belt/chain down so that both were inside the gearbox.
Attaching a plate on the "top" of the caster box would be the biggest challenge, requiring welding or a rather good bar-bending brake.
Unread 30-12-2014, 20:14
AlecMataloni AlecMataloni is offline
Excellence is Bliss
AlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond repute
Hey, this is really neat! I like how this feels very "compact", and doesn't look terribly difficult to machine. You certainly did a good job playing to your team's resources.
I do have one nitpick with this design though.
Right now, from what I can tell, it looks like you have the CIM pinion position determined by your screw locations, which for this application isn't ideal. Screws/rivets do a poor job of "locating" parts in an assembly, and ideally they shouldn't be used to do so. The screw's hole is over sized by design, and this clearance will introduce slop into your CIM shaft's position.
In FRC, this stuff usually doesn't matter a huge amount, except in the case of drive components which require precise distances. Depending on how big the CIM screw holes are sized on the module, your CIM's location and consequently your actual C-C belt distance could be off by more than you'd like.
I would mill a .75" hole for the shaft to go through, and use the .75" OD nub that's on the face of the CIM to properly locate the motor on the part. It'd be a waste to precisely mill all your holes, and still have inaccuracies in the system which could affect how your belt drive behaves.
EDIT: I realized that there's some slotted screw holes for tensioning that I missed; However, I'd still recommend making that hole .75", but extending it as a slot along with the screw holes.
That leads me to another question. How do you go about determining proper tension in your belts? I've struggled with this question for a while, as it seems difficult to do without using expensive instruments. Any tips?
Unread 30-12-2014, 21:10
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
+1 on using the cim boss 0.750" diameter to locate the cim, if you haven't already.
Very neat. I like the belts and the encoder placement.
Unread 30-12-2014, 14:07
avanboekel's Avatar
avanboekel avanboekel is offline
AKA: Adam Van Boekel
FRC #5934 (Gear it Forward, Crowbotics)
avanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant future
You were able to do this on a manual mill? That's pretty impressive!
Do you have any other pictures/ renders?
2338 Gear It Forward | Student 2010-2013 | Mentor 2014-Present | oswegofirst.org
2013 Wisconsin Regional Winner (1732, 111, 2338)
2013 Midwest Regional Dean's List Finalist
2015 Midwest Regional Chairman's Award Winner
2015 Archimedes Subdivision Winner (1023, 2338, 3996, 1089)
2016 Midwest Regional Chairman's Award Winner
4096 CTRL-Z | Mentor 2014 | team4096.org
5934 Crowbotics | Mentor 2016-Present | crowbotics.org
