Go to Post These are threads, and they are what hold the community together...so CD must be a threaded fastener right? - Andrew Blair [more]
Unread 31-12-2014, 00:24
dmpage318 dmpage318 is offline
FRC #1533 (Triple Strange)
dmpage318 is an unknown quantity at this point
Team 1533 Swerve
Team 1533 Triple Strange presents Strange Swerve!
After some experimentation with swerve drive this past summer, we decided to go with a four-wheel independently driven and steered system for the 2015 season. We designed the modules based on Team 221 LLC.'s Revolution 2 modules, but they are slightly more compact. The mounting point is brought down to just above the wheels to reduce cantilever on the modules upon impact with other robots. The swerve module sits in self-contained box with an Andymark 9015 motor with PG71 planetary gearbox for steering and CIM motor to drive. On the Andymark motor is a magnetic absolute position encoder and we plan to add a quadrature encoder to the CIM motor. The boxes allow for quick replacing and will attach to almost any chassis we choose.
On the programming side, we are able to track the robot's position on the field using the encoders on one module and a gyro. Also with the gyro, the robot can use either robot-centric or field-centric controls. Bringing position tracking and field-centric control together, the robot can drive to any target location while at the same time turning to a target angle.
All CAD models, pictures, and Java code are available at:
http://drivebase.team1533.org/
Unread 31-12-2014, 00:37
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
Re: Team 1533 Swerve
If I were you, I would do everything you could to keep that top sheet metal flange from stopping where the modules start.
Unread 31-12-2014, 01:45
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Neat! I like the triforce symbols on the sides.
I will take a look at the cad and see if there's some other cool stuff in here.
What's the weight of each module, with all the motors and gearboxes?
