Java Help
I am going to be programming for my FRC team. This is my first year on FRC and need help learning Java. I have experience programming with Greenfoot which is very similar to Java. Are there any resources for people learning Java for FRC with previous programming knowledge?
Re: Java Help
Here is a thread I started earlier that has presentations that our team gave on Java earlier this season. Please feel free to let me know if you have any questions, my email is in the presentation.
I would use the pdfs in that thread as they are the most up to date. |
Re: Java Help
Re: Java Help
Do you know if your team will be using robotbuilder (or if you have the choice to use it)? If so, I recommend watching this video playlist from the guy who wrote the FRC libraries. It should tell you everything you need to know.
Re: Java Help
You could go through the tutorials on Oracle's website. That should give you enough experience to be able to program something. The robot classes are all pretty straight-forward, so you should be fine.
Re: Java Help
Thanks for everybody's help.
#7
Re: Java Help
If you want even more resources, check out the links in these threads: http://www.chiefdelphi.com/forums/sh...31&postcount=3
#8
Re: Java Help
Thanks again for the many resources. Out of curiosity, are there any tutorials specifically designed for FRC. I do have some Java experience through using Greenfoot.
#9
Re: Java Help
The screensteps documentation should have everything you need to get up and running. Keep in mind this is the 2014 documentation. WPILib has changed a little for the 2015 season and the new controller, so check the site after kickoff when the 2015 documentation should be up.
#10
Re: Java Help
Re: Java Help
Our founder (Gixxy) posted some java resources, including plenty of FRC-specific stuff on our team website:
http://slidell-robotics.com/index.ph...=javaresources |
