Go to Post Parking Lot T-Shirt Bootleggers are NOT approved suppliers - Rich Kressly [more]
Unread 03-01-2015, 20:40
theCADguy's Avatar
theCADguy theCADguy is offline
Design Team Student Leader
AKA: Sean Gibbons
FRC #0020 (The Rocketeers)
Team Role: CAD
theCADguy has a spectacular aura abouttheCADguy has a spectacular aura about
Coopertition...Is it worth it this year?
At first, it seemed to me that the coopertition points were not worth pursuing, due to the fact that they are a tiebreaker, when the primary method of ranking is not nearly as likely to produce ties as it was in the past, and that it only matters for qualification matches, not playoffs.
However, there is a decently sized points reward for a stack (40 teleop points, 20 points for a set). So I wonder, is it worth the effort to stack for co-op points, or is it better strategically to build stacks of grey totes and containers on your own alliance's side? Keep in mind that the action of stacking on the step is different from stacking on the scoring zones, and may require different mechanisms.
So, what do you think?
Unread 03-01-2015, 20:49
2348humanplayer's Avatar
2348humanplayer 2348humanplayer is offline
BIGGEST FRC NERD EVAR!!!!
FRC #2348 (The Cool Geeks)
2348humanplayer is an unknown quantity at this point
Re: Coopertition...Is it worth it this year?
I think it's MORE than worth it. After looking at the manual, I found that a team's rank is not based on W-L-T anymore. It's based on average score through each match. Since the Coopertition bonus is fairly easy to get at least to the 20-point mark, that can lead to a significant boost to all teams ranks that decide to do it.
2000 Silicon Valley Regional
2001 Silicon Valley Regional
2002 Silicon Valley Regional
2002 Championships
2003 Silicon Valley Regional
2008 Hawaii Regional
2010 Hawaii Regional
2011 San Diego Regional
2011 Hawaii Regional
2012 Hawaii Regional
2013 Hawaii Regional
2014 Silicon Valley Regional
Green = Spectated
Blue = Competed as Human Player
Teal = Competed as Coach
Lime = Volunteered at Regional
Unread 03-01-2015, 20:50
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
40 points to lift 2 totes 4 feet off the ground. Seems like a no-brainer for seeding high.
Unread 03-01-2015, 20:54
DJ Carpenter's Avatar
DJ Carpenter DJ Carpenter is offline
Challenge Accepted
FRC #1741 (Red Alert)
DJ Carpenter is an unknown quantity at this point
It is completely worth it if you do The Noodle Agreement, anything else isn't worth the effort.
Unread 03-01-2015, 21:00
jajabinx124's Avatar
jajabinx124 jajabinx124 is offline
Team 2052 Alumnus
AKA: Kshitij Wavre
jajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond repute
In 5.3.4(Qualification seeding) in the manual it explains how it is the 2nd order sort for the ranking criteria at a competition. So I'd say, and it explains itself very well, that it is pretty worth it to implement the cooperation strategy in order rank high at competitions.
Unread 03-01-2015, 23:12
pbhead pbhead is offline
FTC #1123
pbhead is just really nicepbhead is just really nicepbhead is just really nicepbhead is just really nicepbhead is just really nice
I agree. The Noodle Agreement and the coopertition points go hand in hand. If your goal is to beat the other team... whatever (and you are playing the game wrong). If your goal is to score high, and thus seed high, both seem necessary for optimal play.
Assuming the noodle agreement is not nerfed somehow. It is kind of Over Powered at the moment.
Persons attempting to find a motive in this narrative will be prosecuted;
persons attempting to find a moral in it will be banished;
persons attempting to find a plot in it will be shot.
By Order of the Author -Mark Twain
Unread 03-01-2015, 23:36
jtrv's Avatar
jtrv jtrv is offline
github.com/jhtervay
AKA: Justin
FRC #2791 (Shaker Robotics)
jtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to all
I don't think it is necessary, but it will certainly help.
The fact of the matter is - eliminations really don't matter very much. Tell me how many times you've seen a #1 seed lose the tournament. The answer is probably a lot.
Eliminations are what matters, and there is no coopertition in eliminations. If you devote a significant amount of your strategy or build design to doing coopertition, you're not going to do well in elims. Sure, you can do fine. But you won't do fantastic unless you have a spectacular bot.
You have to rely on the fact that the other alliance wants coopertition just as much as you do, and can also even reach to get the fourth tote up. Some teams will not be able to reach. Some teams will not care about coopertition.
For example, the teams seeded 4-12ish are going to care A LOT about coopertition on the second day. The 1-3 and 13-45ish teams will not. That's a vast majority. Those teams need to show off to other teams what they can do ASIDE from coopertition, in order to get the best alliance.
Sure, the first day, there will be a lot. But when it comes down to crunch time, coopertition based strategy won't win you anything.
Besides, if the other alliance doesn't want to do coopertition, you just wasted a lot of valuable time placing the totes on the ledge when you could have been doing other work.
Unread 03-01-2015, 21:10
CalTran's Avatar
CalTran CalTran is online now
Missouri S&T Senior
Is it necessarily even 2 totes? My understanding was that it just had to be a stack of 4 yellow totes, so even contributing 3-1 would be make the cut
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 03-01-2015, 21:17
JesseK's Avatar
FRC #1885 (ILITE)
One alliance does two, the other does two. If an alliance can truly only do one, then fine. Yet it isn't too far a stretch goal to stack two at once on the Step (IMO) if a team plans to stack one on the Step. It's only ~14lbs. Or if it is too far a stretch, then stack two gold totes in 2 trips, going 18" higher on the 2nd trip.
Unread 03-01-2015, 21:24
theCADguy's Avatar
AKA: Sean Gibbons
Team Role: CAD
Also, one alliance could do 3, and the other does 1.
It seems to me now that it is worth it to stack for coopertition. However, I would keep stacking on the scoring zones, with containers, a priority, since coopertition is not nearly as beneficial for playoffs.
Unread 03-01-2015, 21:27
GKrotkov's Avatar
GKrotkov GKrotkov is offline
AKA: Gabriel Krotkov
FRC #1712 (Dawgma)
GKrotkov has much to be proud ofGKrotkov has much to be proud ofGKrotkov has much to be proud ofGKrotkov has much to be proud ofGKrotkov has much to be proud ofGKrotkov has much to be proud ofGKrotkov has much to be proud ofGKrotkov has much to be proud of
Actually, it's not beneficial at all for playoffs! There are no coopertition points in the playoffs.
Unread 03-01-2015, 21:39
dipmeinaluminum's Avatar
dipmeinaluminum dipmeinaluminum is offline
Michael Vilarelle Mentor
AKA: (Former Mentor 354 Westinghouse Pirates)
FRC #0333 (The Megalodons)
dipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to behold
100% worth it this year, why leave points out there!? The robot is already designed to perform the task
Team#333 (2013-Present)
Team#354 (2000-2013)
https://www.youtube.com/watch?v=Bu5-NvMUQ-Y
Unread 03-01-2015, 21:40
dag0620 dag0620 is offline
Because we're FiNE
AKA: David Givens
FRC #1071 (Team MAX)
dag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond repute
Yes (Period).
David Givens
Alumnus Team Max 1071 ('13) | FIRST Volunteer | NE FIRST
Away making magic for a bit...
Unread 03-01-2015, 22:41
Justintime12 Justintime12 is offline
FRC #3880 (Tiki Techs)
Team Role: Student
Justintime12 is an unknown quantity at this point
Coopertition is worth it for tiebreakers and scoring points to help your alliance.
Unread 03-01-2015, 22:55
SciBorg Dave SciBorg Dave is offline
AKA: Dave Tharp
FRC #5920 (VIKotics)
SciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to behold
Worth it yes. I think that it has to be done early before stacks start block the drivers view.
