Go to Post I think this says it all... It's Fantasy FIRST on Chief Delphi. - Zach O [more]
Unread 03-01-2015, 21:41
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
pic: 2015 WCD Clearance Considerations
Unread 03-01-2015, 21:42
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
Re: pic: 2015 WCD Clearance Considerations
just to verify what is this exactly depicting a robot driving over the humps.
-WPI number one seed
-Innovation in controls award
- NECMP#4 seed semifinalist
- 9th in NEW ENGLAND
2008- Connecticut regional winners
2004-UTC new England regional Winners
2001 highest rookie seed award winner
Unread 03-01-2015, 21:44
Chris is me's Avatar
AKA: Pinecone
Seems like 6" wheels and 2" tube are pretty much gonna handle anything the bump can throw at it, which is nice.
Unread 03-01-2015, 22:48
JesseK's Avatar
FRC #1885 (ILITE)
Double-check that you're comfortable with this 0.25" clearance:
Unread 03-01-2015, 23:46
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
.25 is plenty, but mine will have a wheel or 2 between those two, so no problem. pretty sure 4" wheels would work fine too
Unread 04-01-2015, 08:13
JesseK's Avatar
FRC #1885 (ILITE)
in the first picture, those are 6" wheels which do not bottom out. 4" wheels definitely bottom out.
Unread 04-01-2015, 18:25
quantcyg quantcyg is offline
Mechanical Design
AKA: Megan Yamoah
FRC #1678 (Citrus Circuits)
quantcyg is a name known to allquantcyg is a name known to allquantcyg is a name known to allquantcyg is a name known to allquantcyg is a name known to allquantcyg is a name known to all
Depending on the length of your base, you actually can get away with 4" wheels traveling over the platforms. However, with a WCD, you'll need 6" wheels in case you catch the corner of the scoring platform with the front of the drivebase or if you want to drive along the length of the platform.
In short, going with 6" wheels is probably the better option.
TylerS's Avatar
TylerS TylerS is offline
AKA: Tyler Stark
FRC #1747 (Harrison Boiler Robotics)
TylerS will become famous soon enough
Can someone just verify that 1in is enough clearance to not have to worry about the bump?
Purdue University 2019 - Aerospace Engineering
2016 - Team 1747 - Design & Build Mentor
2015 - Team 303 - Coach/Build Captain
2014 - Team 303 - Build Captain
2013 - Team 303 - Driver
2012 - Team 303 - Programming Leader
Unread 04-01-2015, 18:27
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
I don't think catching on the edge of the incline is a deal breaker. While not the most elegant solution, HDPE is very slick plastic and your back wheels would still be touching the ground.
There's also no defined frame perimeter this year, so you can do interesting things with that.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 05-01-2015, 08:09
Jay Burnett Jay Burnett is offline
FRC #5332 (Toaster Tech)
Jay Burnett is an unknown quantity at this point
But if you go with an 8 wheel 4" drive, you could easily make sure that you don't bottom out between wheels. That's assuming you don't go for a super long wheelbase.
Unread 05-01-2015, 08:28
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
To clarify, it's the trackwidth that's the challenge, not the wheelbase. As mentioned, adding additional wheels easily solves the challenges with the wheelbase when you're travelling perpendicular to the scoring platform. However, if you're travelling down the length of the platform (or at more extreme angles towards the platform), the width between your wheels may cause your robot to bottom out if you don't have enough ground clearance.
Unread 05-01-2015, 09:00
oh right. Got it
RockerRobot's Avatar
RockerRobot RockerRobot is offline
AKA: Annabelle Noland
FRC #3021 (The Agency)
RockerRobot is an unknown quantity at this point
I think the point is to Not drive over the scoring platforms. Thats why maneuverability is key this year.
Unread 03-01-2015, 21:47
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
If I want to go get something from the landfill zone from a feeder station why drive around the scoring platforms in some crazy "S" instead of driving strait over them.
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
Jacob Bendicksen's Avatar
Jacob Bendicksen Jacob Bendicksen is offline
Figuring out what's next
Jacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond repute
It's nice to be able to dance around the platforms, sure, but the area in between them is going to get pretty congested with totes and other robots. Being able to drive over the platforms should make things more efficient for you.
Also, they put ramps on them, so they clearly thought that teams would want to drive over them.
jacobbendicksen.com | @jacobbendicksen
Yale University Class of 2020
Team 1540 | 2012-2016
7 Chairman's Awards, 6 other awards, 2015 Dean's List Finalist, 1 event win, 2 finalist finishes. Thanks for an amazing ride.
