Go to Post We're somewhere in the range of ludicrous speed to bench grinder. - Ginger Power [more]
Unread 03-01-2015, 22:15
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
NetConsole plugin for IntelliJ IDEA
I'm now sure how many people here use IntelliJ IDEA, but I'm working on some tools to make it possible to use for FRC. I thought I'd share them here in case anyone finds them useful.
So far I have a NetConsole plugin, similar to the Riolog view in Eclipse this year. If you're not familiar with what this does, it shows any printlns, errors, stack traces, etc from the robot. For example, this:
You can download the plugin here, and install it by going to File > Settings > Plugins, choosing "Install plugin from disk...", and selecting the jar. Let me know if you try it out, or if there are any problems with it. The source is on GitHub here.
Unread 20-01-2015, 14:58
Javaru's Avatar
Javaru Javaru is offline
AKA: Mark
FRC #3838 (RocCity Robotics)
Javaru is an unknown quantity at this point
Re: NetConsole plugin for IntelliJ IDEA
Thanks! I was about to roll my own when I found yours. FYI, the link to your released plugin is broken (404). I was able to build it from source. But others not familiar with how to build a plug-in might struggle a bit. (For others, instructions are located here in the "Deploying a plugin" section.)
Thanks again.
