Go to Post Replay/video isnt a BAD idea, its just not a GOOD idea for FIRST. - Ashley Christine [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 04-01-2015, 20:32
eedoga's Avatar
eedoga eedoga is offline
FRC #2980
eedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud of
TEAM2980 Open Source Robot Thread
Hey Chief Delphi Community,
We are going to post as much as we can about our ideas on this thread. Feel free to comment or use anything that you see here. We will also be posting CAD files and the like.
We start out by dividing our team up into 4 sub teams. Each sub team comes up with a different design for the robot which we then present to our community on the first Friday of build season. We then build the robot that the community votes on. We find that this eliminates a lot of problems down the road.
The other team members will be posting to this thread also.
Wow...another build season is here already.
Edoga
Lead Mentor
FIRST Team 2980
The Whidbey Island Wildcats.
Unread 04-01-2015, 20:53
josephus's Avatar
josephus josephus is offline
FRC #2980
josephus is an unknown quantity at this point
Re: TEAM2980 Open Source Robot Thread
Josephus2015 design group
The main function of our robot is to stack totes inside the frame perimeter. This is done using vertically moving latch mechanisms, nicknamed "chopsticks" to pick up a tote or recycling bin and hold it while another tote is collected underneath, at which point we can lower the "chopsticks", stacking the previously collected tote or bin (tote1/bin) on the newly collected tote (tote2). The process can be repeated as long as the vertical motion actuators can lift the weight of the collected game elements.
Totes are collected and piles ejected using a simple hooked arm mechanism. we will post a picture of this later.
Stacked totes can be set on the step because of their configuration, protruding out of the robot significantly, and the action of the collection/ejection arm.
we plan to use Mechanum wheels to maintain slope ability while maintaining significant maneuverability.
plans to collect bins while maintaining stability are in development.
We may include a simple mechanism to collect detritus litter for disposal in the landfill, this is awaiting discussion considering the noodle agreement, and various other aspects of the game. We plan to post more at a later date.
Unread 05-01-2015, 22:51
Mecanum Wheel's Avatar
Mecanum Wheel Mecanum Wheel is offline
It's spelled mecanum
AKA: Bengt Ilon
Mecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond reputeMecanum Wheel has a reputation beyond repute
mecanum*
Unread 08-01-2015, 12:18
CFTeam2980's Avatar
CFTeam2980 CFTeam2980 is offline
AKA: Chris Felipe
FRC #2980 (Whidbey Island Wildcats)
Team Role: CAD
CFTeam2980 is an unknown quantity at this point
This is the initial CAD Inventor drawing of our robot. Still working in progress...
https://drive.google.com/folderview?...&usp=sha ring
Unread 24-01-2015, 18:54
CFTeam2980's Avatar
AKA: Chris Felipe
Team Role: CAD
We posted a render of our robot. It isn't 100 percent done, but it is pretty well along the way.
Here is a link to the pick.
http://www.chiefdelphi.com/media/photos/41199?
Unread 25-01-2015, 02:30
eedoga's Avatar
FRC #2980
So...a couple of things in response to questions that have been brought up about our team and robot.
Our design process is a bit abnormal...
Right after kick off we divide up into four separate teams. Each team designs a robot using a worksheet that our team uses.
https://docs.google.com/document/d/1...it?usp=sharing
Each team then does a CADD mock up using autodesk inventor during week 1. On Friday night we invite the community. This year we had over 100 people show up for this event.
Each team presents their idea in a 10 minute presentation, and then the entire team leaves the room.
The community including some graduated team members then argue about which design the team should build. This year they chose two different designs and combined them. (We will post the video of this soon...We are waiting for our Video Productions class to finish editing it down.)
We then spend week 2 doing a final CADD of the entire robot. We also use some of this time to prototype things to see what works.
Then we get to work actually building a robot. Week 3 is for Fabrication, and week 4 is for final assembly. We are pretty well on schedule at this point having finished welding our base frame today, and cutting out most of the parts for both lifting mechanisms.
So...This years robot.
We are using 1 lift mechanism to try to do a 3 tote autonomous stack. The plan is to pick up 2 of the totes, and then push the third into position dropping the two we lifted down on top of it. We are planning 3 seconds per tote with a few seconds in between which we understand is ambitious.
We then have a multi-purpose lift mechanism which we plan to use for totes and recycle bins.
We are using a halonomic(sp?) drive base.
Earlier in the thread we linked to a Github which has all of our CADD files posted in it. We have also posted renders of our robot. We will post more in the next few days.
Currently our base is driving around. we will be adding to it tomorrow...
We will post more at the end of the day.
best of luck to all teams.
Edoga
Unread 25-01-2015, 03:14
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Edoga
That's holonomic BTW.
By "the community" do you mean FRC people or parents/ kids etc? Becuase every year we do get input from parents and such during design reviews, but many ideas suggested show a sever lack of experience doing this sort of mechanical stuff (we have plenty of electrical engineers, though).
It looks pretty sweet either way though, and pretty bulletproof. Your elevator is a little less strong that it could be IMO, but I really don't know if you will have any issues. We are using bearings on three sides of the walls of our elevator.
3 seconds/ tote might be tricky if you can't position the arm quickly. One side of your robot needs to pull a stack into it, and the other side needs to laign the tote properly. Either of these tasks can be difficult.
Unread 25-01-2015, 16:42
josephus's Avatar
FRC #2980
Originally Posted by asid61 View Post
By "the community" do you mean FRC people or parents/ kids etc? Because every year we do get input from parents and such during design reviews, but many ideas suggested show a sever lack of experience doing this sort of mechanical stuff (we have plenty of electrical engineers, though).
By "the community" we mean the community. That is, we send out invitations to public officials and specific people or organizations whom we want to come, and we publicize the event widely with an open invitation to anyone who wants to show up. We usually get parents, old engineers, representatives from local sponsors, old team members, naval technicians from our local naval base, possibly state legislatures, other public officials, and people from the general community. Experience combines with common sense in the discussion after the presentations, and there is a Q/A session immediately after the presentations that allows for dynamic input from the design groups.
Our first two years, we decided on robot design without the community and great ideas were passed over by either the mentors lack of faith in the design of the students (which appeared in many robots at competition) or the popularity of the people on one of the design groups. Presenting to the community allows for widespread discussion as well as removal from team biases. It is also a great way to involve the community with FIRST
Unread 26-01-2015, 00:21
eedoga's Avatar
FRC #2980
This weekend was really good for us. We had some real successes and are hopefully back on schedule. I was feeling like things were going too slowly and that too much was up in the air.
Going into this weekend it felt as though we hadn't accomplished anything real. Things were also going really slowly. So cutting out parts seemed to take forever...We would have a meeting and three parts would be made at the end with 1 of them cut out wrong and needing to be redone...Our welding mentor got stuck doing paperwork so we thought we might have to build the robot using rivets and brackets...So we furiously began cutting out brackets and bought out all the rivets the nearest harbor freight had in stock...
So...This weekend...
We drove...Just the base and electronics board, but we drove around using our holonomic drive train.
We got our base frame welded.
We got our battery moving mechanism mounted.
We built the frame of our rear lift mechanism.
We built our front gripper claw frame and mounted the dart linear actuator. (still needs a bit of work, mostly figuring out the bolt needed to connect the bracket we made to the end of it.
We decided things, like using square tube for our gripper rails instead of 80/20, and making an electronics cover using 1/16th polycarb...
We also got in some parts that our material sponsor, Bowman Manufacturing, laser cut for us. (they came in at 7 PM tonight.)
We welded up the practice frame.
Really this next week we can focus on finalizing fabrication and initial assembly, then the Guild, the art club on campus can have at it to make it pretty. :-) (The community stressed that they wanted little artistic flourishes throughout the robot.)
Did I mention that we learned how to anodize!? :-)
What a weekend. The really cool thing is that there is no school on Thursday because we are changing over semesters, so the team gets the whole day to work, though we may break early tomorrow so that people have time to study for their finals.
Honestly though I am feeling much better now than I did even on Friday.
Great work everyone!
Edoga
Unread 26-01-2015, 01:43
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Wow, that's a lot of stuff! You guys are super industrious.
How are you anodizing?
Unread 26-01-2015, 08:05
eedoga's Avatar
FRC #2980
I am going to have the team member who figured it out post a tutorial video by tomorrow showing how to do this. I have him in my robotics class and I think this would be a good activity for him. :-)
Edoga
Unread 04-01-2015, 23:46
Michael U Michael U is offline
Programmer
FRC #2980
Michael U is an unknown quantity at this point
Team M&M (Michael and Mallory) will be posting everything to a GitHub repository.
Unread 05-01-2015, 00:18
Amar Shah Amar Shah is offline
FRC #1899 (Saints Robotics)
Team Role: CAD
Amar Shah has a spectacular aura aboutAmar Shah has a spectacular aura aboutAmar Shah has a spectacular aura about
Have you considered using GrabCAD? It accomplishes a similar purpose, but natively supports CAD files.
Unread 05-01-2015, 17:55
Programmer
FRC #2980
We do use GrabCAD, we are just using GitHub since it can handle many different files and also because it makes team cooperation easier on things like presentations and LabView Code.
